HP Envy 4-1105dx Display Replacement
    1. HP Envy 4-1105dx Display Replacement, Battery: step 1, image 1 of 1
      • Power off the device before beginning disassembly. Disconnect all external devices.
      • Flip the device on its back.
      Ask FixBot
    2. HP Envy 4-1105dx Display Replacement: step 2, image 1 of 1
      • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
      Ask FixBot
    3. HP Envy 4-1105dx Display Replacement: step 3, image 1 of 1
      • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
      Ask FixBot
    4. HP Envy 4-1105dx Display Replacement: step 4, image 1 of 1
      • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
      Ask FixBot
    5. HP Envy 4-1105dx Display Replacement: step 5, image 1 of 1
      • Once the device is open, move the ribbon cable to the side.
      Ask FixBot
    6. HP Envy 4-1105dx Display Replacement: step 6, image 1 of 1
      • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
      Ask FixBot
    7. HP Envy 4-1105dx Display Replacement: step 7, image 1 of 1
      • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
      Ask FixBot
    8. HP Envy 4-1105dx Display Replacement: step 8, image 1 of 1
      • Lift the battery up and remove.
      • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
      Ask FixBot
    1. HP Envy 4-1105dx Display Replacement, Display: step 9, image 1 of 3 HP Envy 4-1105dx Display Replacement, Display: step 9, image 2 of 3 HP Envy 4-1105dx Display Replacement, Display: step 9, image 3 of 3
      • Close the device and turn it right-side up. Locate the two screw covers on the left and right side base of the display panel.
      • Remove the screw covers, using the black plastic spudger.
      • Remove the two 3.0 mm Phillips-front screws on the left and right hinges that secure the display panel to the computer, using a Phillips #1 screwdriver.
      Ask FixBot
    2. HP Envy 4-1105dx Display Replacement: step 10, image 1 of 3 HP Envy 4-1105dx Display Replacement: step 10, image 2 of 3 HP Envy 4-1105dx Display Replacement: step 10, image 3 of 3
      • Pry open the plastic bezel case of the device using the plastic spudger. If the plastic spudger doesn't work, carefully use the metal spudger.
      • Loosen the edges of the case from all four sides of the display panel.
      • Be careful not to use hands while opening, as the edges of the back case are sharp.
      • Once the back case pops out, close the laptop exposing the back display.
      Ask FixBot
    3. HP Envy 4-1105dx Display Replacement: step 11, image 1 of 2 HP Envy 4-1105dx Display Replacement: step 11, image 2 of 2
      • Remove the four 4.0 mm Phillips display panel screws using Phillips #1 screwdriver.
      • Remove the four 2.0 mm Phillips screws using Phillips #00 screwdriver.
      Ask FixBot
    4. HP Envy 4-1105dx Display Replacement: step 12, image 1 of 3 HP Envy 4-1105dx Display Replacement: step 12, image 2 of 3 HP Envy 4-1105dx Display Replacement: step 12, image 3 of 3
      • Remove the four 4.0 mm Phillips silver screws on the hinges using a Phillips #1 screw driver.
      • Remove the two 6.0 mm Phillips black hinge cover screws using a Phillips #0 screw driver.
      • Flip and remove the hinge covers using a plastic spudger.
      • While flipping, be careful not bend the screen brackets.
      Ask FixBot
    5. HP Envy 4-1105dx Display Replacement: step 13, image 1 of 2 HP Envy 4-1105dx Display Replacement: step 13, image 2 of 2
      • Disconnect the ribbon cable on the bottom of the display panel using a plastic spudger.
      • Disconnect the adjacent golden LCD connector using a plastic spudger.
      Ask FixBot
    6. HP Envy 4-1105dx Display Replacement: step 14, image 1 of 1
      • Remove the golden tape adhering to the display panel using a plastic spudger.
      Ask FixBot
    7. HP Envy 4-1105dx Display Replacement: step 15, image 1 of 1
      • Remove the white color wifi antennas from the display panel using a plastic spudger.
      Ask FixBot
    8. HP Envy 4-1105dx Display Replacement: step 16, image 1 of 3 HP Envy 4-1105dx Display Replacement: step 16, image 2 of 3 HP Envy 4-1105dx Display Replacement: step 16, image 3 of 3
      • Separate the transparent plastic tape that covers the circuit board using hands.
      • Carefully flip the circuit board.
      • Remove the black tape adhering to the green circuit board that is connected to the display panel.
      Ask FixBot
    9. HP Envy 4-1105dx Display Replacement: step 17, image 1 of 2 HP Envy 4-1105dx Display Replacement: step 17, image 2 of 2
      • Using a plastic prying tool, remove the display panel.
      • This is the disassembled screen.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 26
Past 30 Days: 97
All Time: 1,430
