HP Envy 4-1105dx Battery Replacement
    1. HP Envy 4-1105dx Battery Replacement, Battery: step 1, image 1 of 1
      • Power off the device before beginning disassembly. Disconnect all external devices.
      • Flip the device on its back.
      Ask FixBot
    2. HP Envy 4-1105dx Battery Replacement: step 2, image 1 of 1
      • Unscrew and remove the one 7.5 mm Phillips-head screw using Phillips #1 screwdriver.
      Ask FixBot
    3. HP Envy 4-1105dx Battery Replacement: step 3, image 1 of 1
      • Unscrew twelve 6.0 mm Phillips-head screws using Phillips #1 screwdriver.
      Ask FixBot
    4. HP Envy 4-1105dx Battery Replacement: step 4, image 1 of 1
      • Use the plastic opening tool (which is short and has a thin end for prying open device parts) to pry open the back case of the device.
      Ask FixBot
    5. HP Envy 4-1105dx Battery Replacement: step 5, image 1 of 1
      • Once the device is open, move the ribbon cable to the side.
      Ask FixBot
    6. HP Envy 4-1105dx Battery Replacement: step 6, image 1 of 1
      • Use the flat end of a plastic spudger to disconnect the battery cable from its socket in the motherboard.
      Ask FixBot
    7. HP Envy 4-1105dx Battery Replacement: step 7, image 1 of 1
      • Unscrew and remove the three 4.0 mm Phillips-head screws that hold the battery in place, using a Phillips #1 screwdriver.
      Ask FixBot
    8. HP Envy 4-1105dx Battery Replacement: step 8, image 1 of 1
      • Lift the battery up and remove.
      • Removing the battery can dislodge the touchpad bracket. Place the battery carefully over the alignment pins.
      Ask FixBot
1 Guide Comment
Worked very well, many thanks
Tony Chan - Reply Share
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 21
All Time: 1,562
