HP Envy 4-1030us Wireless Card Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
92
All Time:
670
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Replacing the wireless (WLAN) card may be necessary for resolving wireless network issues. The card is small with delicate wires clipped to it. Be gentle when wiggling the wires and card free from the system since the contacts are delicate and can affect wireless performance.
When working with electronic components, we recommend wearing an electrostatic wristband, it is possible for the static electricity present on you to discharge onto one of the components, wearing one of these wristbands and clipping it to a piece of metal will prevent this from happening.
Tools
    1. HP Envy 4-1030us Wireless Card Replacement, Bottom Cover: step 1, image 1 of 2 HP Envy 4-1030us Wireless Card Replacement, Bottom Cover: step 1, image 2 of 2
      • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
      Ask FixBot
    2. HP Envy 4-1030us Wireless Card Replacement: step 2, image 1 of 2 HP Envy 4-1030us Wireless Card Replacement: step 2, image 2 of 2
      • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
      • Lift the bottom cover off of the system.
      Ask FixBot
    1. HP Envy 4-1030us Wireless Card Replacement, Wireless Card: step 3, image 1 of 2 HP Envy 4-1030us Wireless Card Replacement, Wireless Card: step 3, image 2 of 2
      • After removing the bottom cover, the wireless card is accessible toward the rear of the system.
      • The wireless card may be underneath a piece or layer of black protective electrical tape. Carefully peel back the tape to access the card.
      Ask FixBot
    2. HP Envy 4-1030us Wireless Card Replacement: step 4, image 1 of 2 HP Envy 4-1030us Wireless Card Replacement: step 4, image 2 of 2
      • Disconnect the wires from the wireless card by lifting them up from the metal studs they are set on.
      • The wires are not screwed onto the studs, but may still require some wiggling or twisting to help them come off.
      Ask FixBot
    3. HP Envy 4-1030us Wireless Card Replacement: step 5, image 1 of 1
      • Using the Phillips #0 screwdriver unscrew the single 2.5mm screw holding the card to the motherboard.
      Ask FixBot
    4. HP Envy 4-1030us Wireless Card Replacement: step 6, image 1 of 1
      • Slide the card out of it's connector.
      • After removing the screw, the card will lift at an angle in its connector.
      Ask FixBot
Christopher Luna
706 Reputation
6 Guides authored
USF Tampa, Team S1-G1, Thompson Fall 2017 Member of USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 92
All Time: 670
