HP Envy 4-1030us Hard Drive Replacement
    1. HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: step 1, image 1 of 2 HP Envy 4-1030us Hard Drive Replacement, Bottom Cover: step 1, image 2 of 2
      • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
      Ask FixBot
    2. HP Envy 4-1030us Hard Drive Replacement: step 2, image 1 of 2 HP Envy 4-1030us Hard Drive Replacement: step 2, image 2 of 2
      • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
      • Lift the bottom cover off of the system.
      Ask FixBot
    1. HP Envy 4-1030us Hard Drive Replacement, Hard Drive: step 3, image 1 of 1
      • After removing the cover the mSATA SSD should be visible near the center of the device.
      • Remove the one Phillips 2.5mm screw holding the SSD in place. The drive should pop up after removing the screw.
      Ask FixBot
    2. HP Envy 4-1030us Hard Drive Replacement: step 4, image 1 of 1
      • To remove the SSD grab the edges and pull it from the slot.
      • Try not to touch any pins or connectors. Damaged pins could result in permanent damage to the system.
      Ask FixBot
Christopher Luna
706 Reputation
6 Guides authored
USF Tampa, Team S1-G1, Thompson Fall 2017 Member of USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 26
All Time: 1,152
