HP Envy 4-1030us CPU Fan Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
24
Past 30 Days:
95
All Time:
843
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 3 - 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
The CPU/processor's internal fan may need to be replaced when the system is experiencing heat related issues. The fan sits atop the heatsink, and is relatively easy to replace, just be sure to gently disconnect the small fan cabling before attempting to remove the fan.
When working with electronic components, we recommend wearing an electrostatic wristband, it is possible for the static electricity present on you to discharge onto one of the components, wearing one of these wristbands and clipping it to a piece of metal will prevent this from happening.
Tools
    1. HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: step 1, image 1 of 2 HP Envy 4-1030us CPU Fan Replacement, Bottom Cover: step 1, image 2 of 2
      • Using the Philips #0 screwdriver, remove the 12 7.5mm screws from the bottom cover.
      Ask FixBot
    2. HP Envy 4-1030us CPU Fan Replacement: step 2, image 1 of 2 HP Envy 4-1030us CPU Fan Replacement: step 2, image 2 of 2
      • Using the plastic opening tool, carefully work the tool between the bottom cover and bottom chassis to loosen the connection.
      • Lift the bottom cover off of the system.
      Ask FixBot
    1. HP Envy 4-1030us CPU Fan Replacement, CPU Fan: step 3, image 1 of 1
      • Using the Phillips #0 screwdriver unscrew the two 4.2mm screws fastening the CPU fan to the heatsink and motherboard.
      Ask FixBot
    2. HP Envy 4-1030us CPU Fan Replacement: step 4, image 1 of 2 HP Envy 4-1030us CPU Fan Replacement: step 4, image 2 of 2
      • Carefully lift up the CPU fan to gain better access to the fan cable.
      • Disconnect the fan cable by pulling the cable away from the connector and remove the fan from the device.
      Ask FixBot
Christopher Luna
706 Reputation
6 Guides authored
USF Tampa, Team S1-G1, Thompson Fall 2017 Member of USF Tampa, Team S1-G1, Thompson Fall 2017
USFT-THOMPSON-F17S1G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 24
Past 30 Days: 95
All Time: 843
