HP Envy 23-d060qd TouchSmart RAM Replacement
    1. HP Envy 23-d060qd TouchSmart RAM Replacement, Back Panel: step 1, image 1 of 1
      • Use your hands to unclip the plastic snaps on the back panel of the device.
      Ask FixBot
    2. HP Envy 23-d060qd TouchSmart RAM Replacement: step 2, image 1 of 1
      • Remove the three 11.5mm PH2 screws from the back panel.
      • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
      Ask FixBot
    3. HP Envy 23-d060qd TouchSmart RAM Replacement: step 3, image 1 of 1
      • Now, take the back panel off by pulling at it gently with your hands.
      Ask FixBot
    1. HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: step 4, image 1 of 2 HP Envy 23-d060qd TouchSmart RAM Replacement, RAM: step 4, image 2 of 2
      • Pop off the easy-access cover to get into the RAM module.
      Ask FixBot
    2. HP Envy 23-d060qd TouchSmart RAM Replacement: step 5, image 1 of 2 HP Envy 23-d060qd TouchSmart RAM Replacement: step 5, image 2 of 2
      • Push out the four clips that hold the RAM modules to the side.
      • The RAM modules will pop open after you unclick all four clips.
      Ask FixBot
    3. HP Envy 23-d060qd TouchSmart RAM Replacement: step 6, image 1 of 1
      • Pull out each module.
      • Replace RAM with desired replacement.
      • When substituting your RAM in, make sure to line up the edges with the lines on the RAM compartment so that the RAM is able to fit inside properly.
      Ask FixBot
5 other people completed this guide.
Zachary Dicks
1,178 Reputation
7 Guides authored
Cal Poly, Team 5-10, Maness Fall 2015 Member of Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 53
All Time: 4,051
