HP Envy 23-d060qd TouchSmart Fan Replacement
    1. HP Envy 23-d060qd TouchSmart Fan Replacement, Back Panel: step 1, image 1 of 1
      • Use your hands to unclip the plastic snaps on the back panel of the device.
      Ask FixBot
    2. HP Envy 23-d060qd TouchSmart Fan Replacement: step 2, image 1 of 1
      • Remove the three 11.5mm PH2 screws from the back panel.
      • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
      Ask FixBot
    3. HP Envy 23-d060qd TouchSmart Fan Replacement: step 3, image 1 of 1
      • Now, take the back panel off by pulling at it gently with your hands.
      Ask FixBot
    1. HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: step 4, image 1 of 2 HP Envy 23-d060qd TouchSmart Fan Replacement, Fan: step 4, image 2 of 2
      • Remove the five 7.5mm T15 screws from the cover plate.
      • Remove the cover plate.
      Ask FixBot
    2. HP Envy 23-d060qd TouchSmart Fan Replacement: step 5, image 1 of 2 HP Envy 23-d060qd TouchSmart Fan Replacement: step 5, image 2 of 2
      • Use your hands to separate the fan's wired connection to the motherboard. Use your hands to gently pull the plastic piece at the ends of the wires.
      • Be gentle when you separate wired connections. Pulling on the wires can damage them.
      Ask FixBot
    3. HP Envy 23-d060qd TouchSmart Fan Replacement: step 6, image 1 of 1
      • Remove the three 8mm T15 screws from the fan.
      Ask FixBot
    4. HP Envy 23-d060qd TouchSmart Fan Replacement: step 7, image 1 of 1
      • Pull the fan loose from the computer.
      Ask FixBot
3 other people completed this guide.
Zachary Dicks
1,178 Reputation
7 Guides authored
Cal Poly, Team 5-10, Maness Fall 2015 Member of Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 74
All Time: 4,541
