HP Envy 17m-ae111dx Screen Replacement
    1. HP Envy 17m-ae111dx Screen Replacement, Screen: step 1, image 1 of 1
      • Orient your laptop so that the casing is laying on the table and the key board is facing you in the air.
      • If your screen is cracked, use a brush to remove excess glass shards.
      Ask FixBot
    2. HP Envy 17m-ae111dx Screen Replacement: step 2, image 1 of 1
      • In this step, you will melt the adhesive around the outside of the screen.
      • Microwave the iOpener Device for 30 seconds. For more instructions on how to properly use the iOpener, please read through our iOpener instructions.
      • Lay the clear side of the iOpener down on the outer edge of the screen to melt the adhesive.
      • Make sure to wait two minutes before microwaving the iOpener again so as to prevent it from bursting.
      Ask FixBot
    3. HP Envy 17m-ae111dx Screen Replacement: step 3, image 1 of 2 HP Envy 17m-ae111dx Screen Replacement: step 3, image 2 of 2
      • Use the iFixit Opening Tool to pry open the screen.
      • Use the iFixit Opening Picks to scrape off the excess glue.
      • Make sure to keep something large wedged between the screen and the cover case to prevent pinching your fingers.
      Ask FixBot
    4. HP Envy 17m-ae111dx Screen Replacement: step 4, image 1 of 3 HP Envy 17m-ae111dx Screen Replacement: step 4, image 2 of 3 HP Envy 17m-ae111dx Screen Replacement: step 4, image 3 of 3
      • Disconnect the power wire.
      • The power wire is the smaller, black wire in the middle of the screen.
      • Disconnect the display wire.
      • The display wire is the wider cable on the left.
      • Remove the screen from the device.
      Ask FixBot
1 Guide Comment
Thanks and by the way this is also equivalent to an hp envy 17-ae013ca
imark7777777 - Reply Share
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 32
All Time: 1,657
