HP Envy 17-3070NR RAM Replacement
    1. HP Envy 17-3070NR RAM Replacement, Back Cover: step 1, image 1 of 2 HP Envy 17-3070NR RAM Replacement, Back Cover: step 1, image 2 of 2
      • Before you begin taking apart the computer, make sure that it is completely powered off.
      • Slide the release latch away from the nearest edge.
      • Slide the back cover off of the computer.
      Ask FixBot
    2. HP Envy 17-3070NR RAM Replacement: step 2, image 1 of 3 HP Envy 17-3070NR RAM Replacement: step 2, image 2 of 3 HP Envy 17-3070NR RAM Replacement: step 2, image 3 of 3
      • Remove the six 3.7mm Phillips screws.
      • Slide the back cover until it clicks, then lift it straight off.
      Ask FixBot
    1. HP Envy 17-3070NR RAM Replacement, RAM: step 3, image 1 of 3 HP Envy 17-3070NR RAM Replacement, RAM: step 3, image 2 of 3 HP Envy 17-3070NR RAM Replacement, RAM: step 3, image 3 of 3
      • Press down on both tabs on either side of the top RAM stick.
      • The RAM will slightly pop out and you will be able to slide it out of it's cavity.
      • Repeat the same process for the second stick of RAM if needed.
      Ask FixBot
Abby Lentz
586 Reputation
4 Guides authored
Cal Poly, Team 14-8, Amido Spring 2015 Member of Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 100
All Time: 1,187
