HP Envy 17-3070NR Optical Drive Replacement
    1. HP Envy 17-3070NR Optical Drive Replacement, Back Cover: step 1, image 1 of 2 HP Envy 17-3070NR Optical Drive Replacement, Back Cover: step 1, image 2 of 2
      • Before you begin taking apart the computer, make sure that it is completely powered off.
      • Slide the release latch away from the nearest edge.
      • Slide the back cover off of the computer.
      Ask FixBot
    2. HP Envy 17-3070NR Optical Drive Replacement: step 2, image 1 of 3 HP Envy 17-3070NR Optical Drive Replacement: step 2, image 2 of 3 HP Envy 17-3070NR Optical Drive Replacement: step 2, image 3 of 3
      • Remove the six 3.7mm Phillips screws.
      • Slide the back cover until it clicks, then lift it straight off.
      Ask FixBot
    1. HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: step 3, image 1 of 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: step 3, image 2 of 3 HP Envy 17-3070NR Optical Drive Replacement, Optical Drive: step 3, image 3 of 3
      • Remove the four 3.7mm Phillips screws that secure the optical drive to the computer.
      • Slowly lift the optical drive away from the computer ensuring that you don't put stress on the connecting cable.
      • Do not fully lift off the optical drive as there is still a cable that connects it to the motherboard.
      Ask FixBot
      • Remove Sub Speaker assembly first in order to remove Optical drive. Carefully disconnect speaker connector.
      Ask FixBot
    2. HP Envy 17-3070NR Optical Drive Replacement: step 5, image 1 of 3 HP Envy 17-3070NR Optical Drive Replacement: step 5, image 2 of 3 HP Envy 17-3070NR Optical Drive Replacement: step 5, image 3 of 3
      • Carefully disconnect the connecting cable by lifting the white clamp with a Flathead screwdriver and pulling on the blue tab away from connector.
      Ask FixBot
Jon Fuson
140 Reputation
1 Guide authored
Cal Poly, Team 14-8, Amido Spring 2015 Member of Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 33
All Time: 1,557
