HP Envy 17-3070NR Battery Replacement
    1. HP Envy 17-3070NR Battery Replacement, Back Cover: step 1, image 1 of 2 HP Envy 17-3070NR Battery Replacement, Back Cover: step 1, image 2 of 2
      • Before you begin taking apart the computer, make sure that it is completely powered off.
      • Slide the release latch away from the nearest edge.
      • Slide the back cover off of the computer.
      Ask FixBot
    2. HP Envy 17-3070NR Battery Replacement: step 2, image 1 of 3 HP Envy 17-3070NR Battery Replacement: step 2, image 2 of 3 HP Envy 17-3070NR Battery Replacement: step 2, image 3 of 3
      • Remove the six 3.7mm Phillips screws.
      • Slide the back cover until it clicks, then lift it straight off.
      Ask FixBot
    1. HP Envy 17-3070NR Battery Replacement, Battery: step 3, image 1 of 2 HP Envy 17-3070NR Battery Replacement, Battery: step 3, image 2 of 2
      • Disconnect the multi-colored battery cable from the main assembly by gently pulling upward on it.
      Ask FixBot
    2. HP Envy 17-3070NR Battery Replacement: step 4, image 1 of 3 HP Envy 17-3070NR Battery Replacement: step 4, image 2 of 3 HP Envy 17-3070NR Battery Replacement: step 4, image 3 of 3
      • Remove the two 3.8 mm Torx screws using M8 Torx screwdriver.
      • Remove the battery by pulling it straight out away from the computer.
      • It is much easier to use the battery cable to carefully lift the battery off than to try to pry it off with tools.
      Ask FixBot
5 other people completed this guide.
Abby Lentz
586 Reputation
4 Guides authored
Cal Poly, Team 14-8, Amido Spring 2015 Member of Cal Poly, Team 14-8, Amido Spring 2015
CPSU-AMIDO-S15S14G8
4 Members
144 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 42
All Time: 9,275
