HP Envy 15-u001dx Screen Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
3
Past 7 Days:
26
Past 30 Days:
111
All Time:
2,298
Comments: 0
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓
The 15.6" screen shows you what the computer is actually doing. Computers still work without a screen, you just can't see what they are doing.
Tools
    1. HP Envy 15-u001dx Screen Replacement, Screen: step 1, image 1 of 1
      • Remove the two screw covers located in the bottom corners of the screen and the 2.5 mm Phillips #0 screws underneath them.
      • If these screws are not removed and you separate the bottom portion of the screen, you will not be able to refasten the screen to the back because the screw tab will break.
      Ask FixBot
    2. HP Envy 15-u001dx Screen Replacement: step 2, image 1 of 2 HP Envy 15-u001dx Screen Replacement: step 2, image 2 of 2
      • Only after removing the two bottom corner screws in Step 1, separate the screen from the back using an opening tool.
      Ask FixBot
    3. HP Envy 15-u001dx Screen Replacement: step 3, image 1 of 1
      • Remove the two 2.5 mm Phillips #0 screws with a Phillips#0 Screwdriver.
      Ask FixBot
    4. HP Envy 15-u001dx Screen Replacement: step 4, image 1 of 1
      • Detach the webcam from the damaged screen using spudger.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Ask FixBot
    5. HP Envy 15-u001dx Screen Replacement: step 5, image 1 of 1
      • Gently detach small white connector with spudger.
      Ask FixBot
    6. HP Envy 15-u001dx Screen Replacement: step 6, image 1 of 1
      • Gently remove the tape with the wire to completely separate the screen.
      Ask FixBot
3 other people completed this guide.
Joshua Madden
682 Reputation
1 Guide authored
USF Tampa, Team 9-4, Lacy Fall 2016 Member of USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 111
All Time: 2,298
