HP Envy 15-u001dx Hard Drive Replacement
    1. HP Envy 15-u001dx Hard Drive Replacement, HP Envy 15-u001dx Disassembly: step 1, image 1 of 1
      • Remove the two no-slip covers on the rear, bottom side using spudger shown in top center of picture.
      • The two in the front do not have to be removed as there are no screws underneath them.
      Ask FixBot
    2. HP Envy 15-u001dx Hard Drive Replacement: step 2, image 1 of 1
      • Remove the two cover tabs towards center of the bottom as there are screws underneath them.
      Ask FixBot
    3. HP Envy 15-u001dx Hard Drive Replacement: step 3, image 1 of 1
      • Remove all fourteen 4.5 mm screws from the bottom using a Phillips #0 screwdriver. Each location is marked by a red circle in the picture.
      Ask FixBot
    4. HP Envy 15-u001dx Hard Drive Replacement: step 4, image 1 of 1
      • Separate the top cover by using a spudger to go around the sides freeing the inside latches.
      • Once the bottom is free, carefully open to the inside as there are two ribbons that connect your keyboard and touch pad to the top cover.
      Ask FixBot
    5. HP Envy 15-u001dx Hard Drive Replacement: step 5, image 1 of 2 HP Envy 15-u001dx Hard Drive Replacement: step 5, image 2 of 2
      • Use the spudger to detach the two ribbons from their connectors.
      • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
      Ask FixBot
    1. HP Envy 15-u001dx Hard Drive Replacement, Hard Drive: step 6, image 1 of 1
      • Gently remove hard drive from its connector.
      Ask FixBot
2 other people completed this guide.
Dakota Presley
885 Reputation
6 Guides authored
USF Tampa, Team 9-4, Lacy Fall 2016 Member of USF Tampa, Team 9-4, Lacy Fall 2016
USFT-LACY-F16S9G4
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 2,614
