HP Elitebook Folio 9470m RAM Replacement
Views: 7.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
20
Past 30 Days:
120
All Time:
7,908
Comments: 1
1 guide comment.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
RAM, or random access memory, is short-term storage for your HP Elitebook Folio 9470m. RAM is used by your processor for immediate use as-needed, unlike long-term files written to a hard disk drive. If your computer has slowed considerably or you’re looking for a boost, replacing/upgrading the RAM is a fairly simple and inexpensive first step. The HP Elitebook Folio 9470m laptop comes standard with 16GB of RAM and can be upgraded to a maximum of 16GB with its two (DDR3) slots.
Tools
    1. HP Elitebook Folio 9470m RAM Replacement, RAM: step 1, image 1 of 1
      • Remove battery using this guide here.
      Ask FixBot
    2. HP Elitebook Folio 9470m RAM Replacement: step 2, image 1 of 3 HP Elitebook Folio 9470m RAM Replacement: step 2, image 2 of 3 HP Elitebook Folio 9470m RAM Replacement: step 2, image 3 of 3
      • Unscrew 2 Phillips head screws, lift slightly up and out to remove hard drive cover.
      Ask FixBot
    3. HP Elitebook Folio 9470m RAM Replacement: step 3, image 1 of 3 HP Elitebook Folio 9470m RAM Replacement: step 3, image 2 of 3 HP Elitebook Folio 9470m RAM Replacement: step 3, image 3 of 3
      • Remove the three Phillips screws from the back plate. Pull slightly up and out to remove the plate.
      • These screws are also marked with a small RAM icon.
      Ask FixBot
    4. HP Elitebook Folio 9470m RAM Replacement: step 4, image 1 of 3 HP Elitebook Folio 9470m RAM Replacement: step 4, image 2 of 3 HP Elitebook Folio 9470m RAM Replacement: step 4, image 3 of 3
      • Gently push out the small tabs on either side.
      • The RAM should pop up and easily be taken out from there.
      Ask FixBot
7 other people completed this guide.
Kenneth Bowers
1,444 Reputation
7 Guides authored
1 Guide Comment
There are 2 black Philips screws more you have to loose, before you can open the back plate. One on the left side (near wifi card), and on right side.
Mikael Salo - Reply Share
Past 24 Hours: 2
Past 7 Days: 20
Past 30 Days: 120
All Time: 7,908
