HP Elitebook Folio 9470m Keyboard Replacement
    1. HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: step 1, image 1 of 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: step 1, image 2 of 3 HP Elitebook Folio 9470m Keyboard Replacement, Keyboard: step 1, image 3 of 3
      • Flip laptop over.
      Ask FixBot
    2. HP Elitebook Folio 9470m Keyboard Replacement: step 2, image 1 of 2 HP Elitebook Folio 9470m Keyboard Replacement: step 2, image 2 of 2
      • Remove battery by pushing slide over to red, lifting slightly up while pulling the battery out.
      Ask FixBot
    3. HP Elitebook Folio 9470m Keyboard Replacement: step 3, image 1 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 3, image 2 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 3, image 3 of 3
      • Remove hard drive cover plate by unscrewing the 2 Phillips head screws and lifting slightly up and out.
      Ask FixBot
    4. HP Elitebook Folio 9470m Keyboard Replacement: step 4, image 1 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 4, image 2 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 4, image 3 of 3
      • Remove back cover by unscrewing the 3 Phillips head screws, then lift the plate up and out.
      Ask FixBot
    5. HP Elitebook Folio 9470m Keyboard Replacement: step 5, image 1 of 1
      • Remove the 4 Phillips head keyboard screws.
      • The screws are also marked with small keyboard icons to distinguish them.
      Ask FixBot
    6. HP Elitebook Folio 9470m Keyboard Replacement: step 6, image 1 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 6, image 2 of 3 HP Elitebook Folio 9470m Keyboard Replacement: step 6, image 3 of 3
      • Flip the laptop over and locate the 2 tabs on the left or right sides. They will be slightly visible in the space between the keyboard and frame.
      • Using a plastic opening tool, push the tabs in while pulling up to disconnect the tabs from the keyboard frame.
      • Once both tabs become unclipped, lift the keyboard up gently allowing it to slightly bend as the front and back tabs come out.
      Ask FixBot
    7. HP Elitebook Folio 9470m Keyboard Replacement: step 7, image 1 of 2 HP Elitebook Folio 9470m Keyboard Replacement: step 7, image 2 of 2
      • While lifting the keyboard up only enough to see underneath, unclip and remove the ribbon wire to fully detach the keyboard.
      Ask FixBot
Kenneth Bowers
1,444 Reputation
7 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 59
All Time: 6,517
