HP Elitebook 8570w Optical Drive Replacement
Views: 2.5K
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
94
All Time:
2,494
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 8 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This replacement guide will show you how to disconnect the optical drive from your HP EliteBook 8570w. It consists of 4 relatively easy steps that should guide you successfully.
Tools
    1. HP Elitebook 8570w Optical Drive Replacement, Optical Drive: step 1, image 1 of 1
      • Begin by removing the computers back covering.
      • Use the right slider to unlock the backing.
      • Slide the backing towards you while holding the slider to remove it.
      Ask FixBot
    2. HP Elitebook 8570w Optical Drive Replacement: step 2, image 1 of 1
      • Once the backing is removed, locate the panel to the left where the optical drive is stored.
      • Locate the single screw in the photo.
      • Unscrew the 0.8mm Phillips screw and place to the side.
      Ask FixBot
    3. HP Elitebook 8570w Optical Drive Replacement: step 3, image 1 of 1
      • Locate the small metal piece in the photo.
      • Using a tool, push the piece in the given direction.
      Ask FixBot
    4. HP Elitebook 8570w Optical Drive Replacement: step 4, image 1 of 2 HP Elitebook 8570w Optical Drive Replacement: step 4, image 2 of 2
      • Once pushing the piece outwards, the optical drive will pop out of the side of the computer.
      • Grab the optical drive and carefully remove it from the back of the computer.
      Ask FixBot
MJ Routh
477 Reputation
3 Guides authored
Baylor, Team S8-G5, Johnson Fall 2017 Member of Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 94
All Time: 2,494
