Introduction
This replacement guide will show you how to disconnect the keyboard from your HP EliteBook 8570w. It consists of 7 moderately difficult steps that should guide you successfully.
Begin by removing the back cover of the computer.
Push the marked slider to the right.
While pushing the slider, pull the cover towards yourself to remove.
Tool used on this step:Tweezers$4.99
Locate the white rectangle base beneath the blue and white strip attached to the computer and keyboard.
Using a wedging tool, pull the white base up slightly to loosen the grip on the blue and white strip.
With the white base slightly risen, use tweezers to carefully pull out/remove the strip from the computer.
Locate the white rectangle base beneath the burn orange strip attached to the computer and the keyboard.
Like the previous step, use a plastic or nylon tool to slightly raise the white base to loosen the grip on the ribbon cable.
Using tweezers or your fingers, carefully pull up on the ribbon cable to completely detach it from the computer.
4 other people completed this guide.
