HP Elitebook 8570w Display Replacement
    1. HP Elitebook 8570w Display Replacement, Display: step 1, image 1 of 3 HP Elitebook 8570w Display Replacement, Display: step 1, image 2 of 3 HP Elitebook 8570w Display Replacement, Display: step 1, image 3 of 3
      • With the computer opened, locate the square buttons on both bottom corners of the display.
      • Using a tool or finger, wedge the squares off revealing a screw on each corner.
      Ask FixBot
    2. HP Elitebook 8570w Display Replacement: step 2, image 1 of 1
      • Use a T9 screwdriver to unscrew both 0.4mm Torx screws.
      Ask FixBot
    3. HP Elitebook 8570w Display Replacement: step 3, image 1 of 2 HP Elitebook 8570w Display Replacement: step 3, image 2 of 2
      • Use an opening tool or spudger to peel back the outer rim of the display.
      • Continue to peel back the entire rim.
      Ask FixBot
    4. HP Elitebook 8570w Display Replacement: step 4, image 1 of 1
      • Unscrew ONLY the bottom 0.8mm T9 Torx screw on both sides of the display.
      Ask FixBot
    5. HP Elitebook 8570w Display Replacement: step 5, image 1 of 3 HP Elitebook 8570w Display Replacement: step 5, image 2 of 3 HP Elitebook 8570w Display Replacement: step 5, image 3 of 3
      • Now locate the two screws on each side at the bottom of the display.
      • TOP screw: unscrew partially.
      • BOTTOM screw: completely unscrew and set to the side.
      • Complete on both sides of display.
      • Carefully separate the display from the top cover.
      • Be sure to not let the top cover fall back
      Ask FixBot
    6. HP Elitebook 8570w Display Replacement: step 6, image 1 of 2 HP Elitebook 8570w Display Replacement: step 6, image 2 of 2
      • Use a Phillips #00 screwdriver to unscrew all four 0.8 mm screws from the left side of the display frame. Repeat for the right side.
      • Push the metal plates/rods that were attached to the display towards the top cover.
      • The display should be completely free of the top cover and able to lay flat on the keyboard (refer to photo #2).
      Ask FixBot
    7. HP Elitebook 8570w Display Replacement: step 7, image 1 of 3 HP Elitebook 8570w Display Replacement: step 7, image 2 of 3 HP Elitebook 8570w Display Replacement: step 7, image 3 of 3
      • With the display laying on the keyboard, locate the black square panel marked in the photo.
      • Grab the side marked in photo #2 and pull it towards you peeling off the surrounding tape and releasing it from the actual display board.
      • This will then remove the connection between the display and the top cover.
      Ask FixBot
4 other people completed this guide.
MJ Routh
477 Reputation
3 Guides authored
Baylor, Team S8-G5, Johnson Fall 2017 Member of Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
3 Members
48 Guides authored
2 Guide Comments
this guide is really bad, dangerous and should be removed !
at step 3 you crack and kill the existing display. If it was still somewhat working before now you are assured it is completely dead !
adrenochrome - Reply Share
agreed, step 3 should use the opening tool on a top corner of the bezel, not against the screen. you just screwed up the screen if it worked at all
Hidden Djinn - Reply Share
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 105
All Time: 4,508
