HP Elitebook 8460p Optical Drive Replacement
    1. HP Elitebook 8460p Optical Drive Replacement, Battery: step 1, image 1 of 1
      • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
      Ask FixBot
    2. HP Elitebook 8460p Optical Drive Replacement: step 2, image 1 of 1
      • Slide the battery away from the switches until it can be lifted away from the laptop.
      • Lift the battery away from the laptop.
      Ask FixBot
    1. HP Elitebook 8460p Optical Drive Replacement, Back Panel: step 3, image 1 of 1
      • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
      Ask FixBot
    2. HP Elitebook 8460p Optical Drive Replacement: step 4, image 1 of 1
      • Slide the back shell of the laptop away from the switches until it can be lifted up.
      • Lift the shell straight up.
      Ask FixBot
    1. HP Elitebook 8460p Optical Drive Replacement, Optical Drive: step 5, image 1 of 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: step 5, image 2 of 3 HP Elitebook 8460p Optical Drive Replacement, Optical Drive: step 5, image 3 of 3
      • Using a Phillips #0 bit, unscrew the one Phillips head screw.
      • Using a T2 Torx screwdriver, remove the two 8.0mm Torx screws.
      Ask FixBot
    2. HP Elitebook 8460p Optical Drive Replacement: step 6, image 1 of 2 HP Elitebook 8460p Optical Drive Replacement: step 6, image 2 of 2
      • With your fingernail, pry the edge of the optical drive away from the chassis of the laptop and pull it straight out.
      Ask FixBot
    3. HP Elitebook 8460p Optical Drive Replacement: step 7, image 1 of 3 HP Elitebook 8460p Optical Drive Replacement: step 7, image 2 of 3 HP Elitebook 8460p Optical Drive Replacement: step 7, image 3 of 3
      • Skip this step if you are removing the optical drive to fix or replace a different component in the laptop.
      • Using a small paper clip, push the paper clip straight in to open the optical drive.
      Ask FixBot
    4. HP Elitebook 8460p Optical Drive Replacement: step 8, image 1 of 3 HP Elitebook 8460p Optical Drive Replacement: step 8, image 2 of 3 HP Elitebook 8460p Optical Drive Replacement: step 8, image 3 of 3
      • Using a small point, pop the tab out.
      • Rotate the plastic cover clockwise to release the tab on the left hand side of the optical drive.
      Ask FixBot
4 other people completed this guide.
1 Guide Comment
Thanks for your help sir and I am really grateful
Mubarak Abubakar - Reply Share
Past 24 Hours: 3
Past 7 Days: 25
Past 30 Days: 82
All Time: 1,778
