HP Elitebook 8460p Modem Card Replacement
    1. HP Elitebook 8460p Modem Card Replacement, Battery: step 1, image 1 of 1
      • On the back of the computer, slide the left switch towards the outside of the laptop until you hear a click.
      Ask FixBot
    2. HP Elitebook 8460p Modem Card Replacement: step 2, image 1 of 1
      • Slide the battery away from the switches until it can be lifted away from the laptop.
      • Lift the battery away from the laptop.
      Ask FixBot
    1. HP Elitebook 8460p Modem Card Replacement, Back Panel: step 3, image 1 of 1
      • On the back of the laptop, slide the right switch toward the outside of the laptop until you hear a click.
      Ask FixBot
    2. HP Elitebook 8460p Modem Card Replacement: step 4, image 1 of 1
      • Slide the back shell of the laptop away from the switches until it can be lifted up.
      • Lift the shell straight up.
      Ask FixBot
    1. HP Elitebook 8460p Modem Card Replacement, Modem Card: step 5, image 1 of 2 HP Elitebook 8460p Modem Card Replacement, Modem Card: step 5, image 2 of 2
      • Attach an ESD strap to your wrist and to a ground.
      • Using a Phillips #0 bit, remove the two 3.0 mm screws and set them off to the side side on a magnetic surface.
      Ask FixBot
    2. HP Elitebook 8460p Modem Card Replacement: step 6, image 1 of 2 HP Elitebook 8460p Modem Card Replacement: step 6, image 2 of 2
      • Push down on one corner of the sound card and lift it straight up.
      Ask FixBot
    3. HP Elitebook 8460p Modem Card Replacement: step 7, image 1 of 2 HP Elitebook 8460p Modem Card Replacement: step 7, image 2 of 2
      • Disconnect the wire plug by grasping the sound card in one hand and the wire in another and pulling them apart.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 81
All Time: 2,370
