HP Elitebook 840 G8 Display Assembly Replacement
    1. HP Elitebook 840 G8 Display Assembly Replacement, Before you begin: step 1, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement, Before you begin: step 1, image 2 of 2
      • Before starting your repair, allow your laptop's battery to drain below 25%—a charged lithium-ion battery is a potential safety hazard if accidentally damaged.
      • Save your work, fully shut down your laptop, and unplug all cables.
      Ask FixBot
    1. HP Elitebook 840 G8 Display Assembly Replacement, Unfasten the bottom cover: step 2, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement, Unfasten the bottom cover: step 2, image 2 of 2
      • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
      • Use a Phillips screwdriver to fully loosen (but not remove) the five captive screws securing the bottom cover.
      Ask FixBot
    2. HP Elitebook 840 G8 Display Assembly Replacement, Release the bottom cover clips: step 3, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Release the bottom cover clips: step 3, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Release the bottom cover clips: step 3, image 3 of 3
      • Position your laptop so the rear edge (with the screen hinge) is closest to you.
      • Insert the flat end of a spudger between the rear edge of the bottom cover and the frame, near the middle screw and ELITEBOOK text.
      • If you're having trouble inserting your spudger, make sure the screw is fully loosened. If necessary, use your fingers to gently pull the screw up.
      • Use your spudger to pry up the cover to release the clip securing it.
      • Leave the spudger inserted under the bottom cover for the next step.
      Ask FixBot
    3. HP Elitebook 840 G8 Display Assembly Replacement: step 4, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement: step 4, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement: step 4, image 3 of 3
      • Slide your spudger along the rear edge toward one of the corners to release the rear edge clips.
      • Rotate your spudger around the corner and up the edge to release the clips securing the short edge of the cover.
      Ask FixBot
    4. HP Elitebook 840 G8 Display Assembly Replacement: step 5, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement: step 5, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement: step 5, image 3 of 3
      • Reinsert the flat end of a spudger near the ELITEBOOK text.
      • Repeat the previous step for the other side of the cover to release the remaining clips.
      Ask FixBot
    5. HP Elitebook 840 G8 Display Assembly Replacement, Remove the bottom cover: step 6, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Remove the bottom cover: step 6, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Remove the bottom cover: step 6, image 3 of 3
      • Lift and remove the bottom cover.
      • The cover should lift away easily. If you feel resistance, use the flat end of a spudger to release any remaining clips, and check that all screws are fully loosened.
      • During reassembly, slide the clips along the front edge of the cover (opposite the hinge) into their slots on the frame, then lay the cover down. Press firmly around the perimeter to engage all of the clips.
      Ask FixBot
    1. HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the battery: step 7, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the battery: step 7, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the battery: step 7, image 3 of 3
      • Position your laptop so the front edge (opposite the screen hinges) is closest to you.
      • Use the point of a spudger or your fingernail to push on alternating sides of the battery's sliding connector to walk it completely out of its socket.
      Ask FixBot
    1. HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the WLAN module cables: step 8, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the WLAN module cables: step 8, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the WLAN module cables: step 8, image 3 of 3
      • Slide an arm of a pair of angled tweezers under the metal neck of one of the coaxial connectors on the WLAN (Wi-Fi) module, located just below the fan.
      • Lift straight up to disconnect the cable.
      • Repeat to disconnect the second connector.
      • During reassembly:
      • Connect the cable with black tape to the socket with a black arrow below it, and the cable with white tape to the socket with a white arrow.
      • Use tweezers to hold a connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again. Don't use excessive force.
      Ask FixBot
    1. HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the display cable: step 9, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the display cable: step 9, image 2 of 2
      • Use your fingers to grip the plastic pull tab on the right display cable press connector, below the fan.
      • Pull straight up to disconnect the connector.
      • During reassembly, align the connector carefully over its socket and press down with your fingertip—first on one side, then the other—until it clicks into place. Don't try to force the connector into place. If you're having trouble, reposition it and try again. Don't use excessive force.
      Ask FixBot
    2. HP Elitebook 840 G8 Display Assembly Replacement, Peel up the fan tape: step 10, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement, Peel up the fan tape: step 10, image 2 of 2
      • Use tweezers or your fingers to peel up the cable tape near the right side of the fan.
      • You don't need to fully remove the tape—it can stay on the cable.
      Ask FixBot
    3. HP Elitebook 840 G8 Display Assembly Replacement, De‑route the fan cables: step 11, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement, De‑route the fan cables: step 11, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement, De‑route the fan cables: step 11, image 3 of 3
      • Use your fingers to pull the display cable and two coaxial cables out from their clips on the right side of the fan.
      • During reassembly, use this photo as a reference to properly route the cables into their clips.
      Ask FixBot
    1. HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the power connector cable: step 12, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the power connector cable: step 12, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the power connector cable: step 12, image 3 of 3
      • Use the point of a spudger or your fingernail to push on alternating sides of the power connector's sliding connector to walk it completely out of its socket near the left hinge.
      • During reassembly, make sure the side of the connector marked with a black dot is facing up before reconnecting the cable.
      Ask FixBot
    2. HP Elitebook 840 G8 Display Assembly Replacement: step 13, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement: step 13, image 2 of 2
      • Use tweezers or your fingers to pull the power connector cable out of its clip.
      • During reassembly, use this photo as a reference to properly route the cable into its clips.
      Ask FixBot
    1. HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the display cable: step 14, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement, Disconnect the display cable: step 14, image 2 of 2
      • Use your fingers to grip the plastic pull tab on the left display cable press connector, near the left hinge.
      Ask FixBot
    2. HP Elitebook 840 G8 Display Assembly Replacement: step 15, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement: step 15, image 2 of 2
      • Use tweezers or your fingers to pull the display cable out of its clip.
      Ask FixBot
    3. HP Elitebook 840 G8 Display Assembly Replacement: step 16, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement: step 16, image 2 of 2
      • Use your fingers or tweezers to lift the display and antenna cables out of their clip near the right hinge.
      Ask FixBot
    4. HP Elitebook 840 G8 Display Assembly Replacement, Fully open your laptop: step 17, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement, Fully open your laptop: step 17, image 2 of 2
      • Fully open your laptop and set it keyboard-side down on a flat, clean work surface, with the display closest you.
      • During reassembly, if your screen clicks or snaps when it's opened or closed, loosen the screws and realign the screen.
      Ask FixBot
    5. HP Elitebook 840 G8 Display Assembly Replacement, Remove the hinge screws: step 18, image 1 of 2 HP Elitebook 840 G8 Display Assembly Replacement, Remove the hinge screws: step 18, image 2 of 2
      • Use a Phillips screwdriver to remove the six 4.6 mm‑long hinge screws—four in one hinge and two in the other.
      • Before installing any hinge screws, make sure the display is properly aligned.
      • Tighten the hinge screws in ascending order based on the number stamped next to each screw hole.
      Ask FixBot
    6. HP Elitebook 840 G8 Display Assembly Replacement, Remove the display assembly: step 19, image 1 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Remove the display assembly: step 19, image 2 of 3 HP Elitebook 840 G8 Display Assembly Replacement, Remove the display assembly: step 19, image 3 of 3
      • Grip the display assembly near the hinges and lift straight up to remove it.
      • You may need to hold down the main body while guiding the hinges out of their recesses.
      • During reassembly, make sure both hinges on your replacement display assembly are fully open before lowering them into their recesses.
      Ask FixBot
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
Carsten Frauenheim
168,854 Reputation
437 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 26
Past 30 Days: 156
All Time: 2,118
