HP Elitebook 840 G1 RAM Replacement
    1. HP Elitebook 840 G1 RAM Replacement, Battery: step 1, image 1 of 1
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Slide the latch, to the right, away from the lock symbol.
      • Slide the cover away from the latch to remove it.
      Ask FixBot
    2. HP Elitebook 840 G1 RAM Replacement: step 2, image 1 of 1
      • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
      • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
      Ask FixBot
    3. HP Elitebook 840 G1 RAM Replacement: step 3, image 1 of 1
      • Battery should easily be lifted up and out.
      Ask FixBot
    1. HP Elitebook 840 G1 RAM Replacement, RAM: step 4, image 1 of 1
      Tool used on this step:
      Anti-Static Wrist Strap
      $7.95
      Buy
      • Identify the RAM and the pull tabs that will be used in the next step.
      • Always use an anti-static wrist strap when working on a computer.
      Ask FixBot
    2. HP Elitebook 840 G1 RAM Replacement: step 5, image 1 of 1
      • Pull back the two tabs on either side of the RAM this will allow the RAM to be removed.
      • When handling a memory module, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
      Ask FixBot
    3. HP Elitebook 840 G1 RAM Replacement: step 6, image 1 of 1
      • Pull the RAM stick gently out and up once the tabs have been pulled to the side.
      Ask FixBot
8 other people completed this guide.
Ashley Williams
2,497 Reputation
5 Guides authored
USF Tampa, Team 5-3, Blackwell Fall 2015 Member of USF Tampa, Team 5-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G3
4 Members
60 Guides authored
1 Guide Comment
Bonjour,
Ce tuto est clair, merci ! :)
christophe.ducard - Reply Share
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 139
All Time: 10,307
