HP Elitebook 840 G1 Battery Replacement
    1. HP Elitebook 840 G1 Battery Replacement, Battery: step 1, image 1 of 1
      • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
      • Slide the latch, to the right, away from the lock symbol.
      • Slide the cover away from the latch to remove it.
      Ask FixBot
    2. HP Elitebook 840 G1 Battery Replacement: step 2, image 1 of 1
      • Once the cover is removed you will be able to see the battery and the two latches that hold it in place.
      • The two latches should be pulled back, one of which is spring loaded and must be held in place in order to remove the battery.
      Ask FixBot
    3. HP Elitebook 840 G1 Battery Replacement: step 3, image 1 of 1
      • Battery should easily be lifted up and out.
      Ask FixBot
27 other people completed this guide.
Ashley Williams
2,455 Reputation
5 Guides authored
USF Tampa, Team 5-3, Blackwell Fall 2015 Member of USF Tampa, Team 5-3, Blackwell Fall 2015
USFT-BLACKWELL-F15S5G3
4 Members
60 Guides authored
2 Guide Comments
Where do I buy another battery and how long does it last on the laptop? 4hr or more?
Vikshay Vuthavadoo - Reply Share
Passt auch für HP Elitebook 850 G2.
Die Anleitung und der Ersatzakku konnten auch bei einem HP Elitebook 850 G2 (Bezeichnung lt. Systeminfo des Notebooks) verwendet werden, das der Akku exakt der gleiche war (HP CM03)
Raller - Reply Share
Past 24 Hours: 2
Past 7 Days: 38
Past 30 Days: 175
All Time: 82,368
