HP Elitebook 820 G2 Network Card Replacement
Views: 3.8K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
101
All Time:
3,766
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The network card is the chip that allows you to connect to your home or local WiFi. If you are unable to connect, networks not showing up, then the network card could be causing the problem. If turning on your network capabilities under your computer settings doesn’t work, then this guide will show you how to replace a faulty network card.
Tools
    1. HP Elitebook 820 G2 Network Card Replacement, Back Panel: step 1, image 1 of 2 HP Elitebook 820 G2 Network Card Replacement, Back Panel: step 1, image 2 of 2
      • Slide the lever firmly to the left on the back panel.
      • Once the back panel is unlocked, there should be red showing to the right of the lever.
      Ask FixBot
    2. HP Elitebook 820 G2 Network Card Replacement: step 2, image 1 of 2 HP Elitebook 820 G2 Network Card Replacement: step 2, image 2 of 2
      • Slide the back panel towards you.
      • Lift the back panel to remove it.
      Ask FixBot
    1. HP Elitebook 820 G2 Network Card Replacement, Network Card: step 3, image 1 of 2 HP Elitebook 820 G2 Network Card Replacement, Network Card: step 3, image 2 of 2
      • Use a Phillips #0 screwdriver to remove the 2 mm head screw on the side of the network card.
      • The card will pop up at an angle after the screw is removed like this.
      Ask FixBot
    2. HP Elitebook 820 G2 Network Card Replacement: step 4, image 1 of 1
      • After the screw is removed, the card can be wiggled back and forth while gently pulling backwards to take it out of its slot on the motherboard.
      • Disconnect the two leads on the other screw side of the card. You have now removed the network card.
      • The leads and their connections on the card are labeled.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Note, when replacing the connections on the network card, they must be plugged in to the correct connections. Both the cables from the motherboard and connections on the network card are labeled.
5 other people completed this guide.
1 Guide Comment
My HP 820 G2’s WiFi/Bluetooth card was working bit intermittently. Especially Bluetooth was reconnecting all the time with my speakers if I didn’t listen to music.
I didn’t find any information which WiFi/Bluetooth card might be a good choice to upgrade. I took a chance and just ordered Intel 9260NGW card. It seems to work fine after couple hours; don’t know how it’ll be in the long run. My original card was Intel 7265NGW.
NGW = NGFF = M.2 slot, source: https://www.dell.com/community/Laptops-G...
Juho Itä - Reply Share
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 101
All Time: 3,766
