HP Elitebook 820 G1 RAM Replacement
    1. HP Elitebook 820 G1 RAM Replacement, Battery: step 1, image 1 of 1
      • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
      • Turn over laptop so that the bottom is showing.
      • Unlock the latch.
      Ask FixBot
    2. HP Elitebook 820 G1 RAM Replacement: step 2, image 1 of 1
      • Remove the back cover and you will then be able to see the battery.
      Ask FixBot
    3. HP Elitebook 820 G1 RAM Replacement: step 3, image 1 of 1
      • Unlatch the two latches securing the battery in the case.
      Ask FixBot
    4. HP Elitebook 820 G1 RAM Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to lift and remove the battery.
      Ask FixBot
    1. HP Elitebook 820 G1 RAM Replacement, RAM: step 5, image 1 of 1
      • Once the battery is removed from the device, slide both latches away from the RAM module with your fingers.
      • The latches are spring assisted and the RAM module will lift for removal.
      Ask FixBot
2 other people completed this guide.
Ashley Francavilla
103 Reputation
1 Guide authored
USF Tampa, Team S5-G1, Eyestone Spring 2018 Member of USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 22
Past 30 Days: 78
All Time: 1,819
