HP Elitebook 820 G1 Monitor Display Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
27
Past 30 Days:
101
All Time:
4,259
Comments: 5
4 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
Displays can get easily damaged either with time, or with any liquids or impacts.
Tools
    1. HP Elitebook 820 G1 Monitor Display Replacement, Battery: step 1, image 1 of 1
      • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
      • Turn over laptop so that the bottom is showing.
      • Unlock the latch.
      Ask FixBot
    2. HP Elitebook 820 G1 Monitor Display Replacement: step 2, image 1 of 1
      • Remove the back cover and you will then be able to see the battery.
      Ask FixBot
    3. HP Elitebook 820 G1 Monitor Display Replacement: step 3, image 1 of 1
      • Unlatch the two latches securing the battery in the case.
      Ask FixBot
    4. HP Elitebook 820 G1 Monitor Display Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to lift and remove the battery.
      Ask FixBot
    1. HP Elitebook 820 G1 Monitor Display Replacement, Fan: step 5, image 1 of 1
      • Remove the hard drive by unscrewing the four 8mm screws with the T7 philip's head.
      Ask FixBot
    2. HP Elitebook 820 G1 Monitor Display Replacement: step 6, image 1 of 1
      • Pry off ten rubber paddings on the outer edge of the laptop to reveal the torx screws.
      • Unscrew the ten 8mm torx screws that are under the rubber paddings using the T7 tip torx screwdriver.
      Ask FixBot
    3. HP Elitebook 820 G1 Monitor Display Replacement: step 7, image 1 of 1
      • Remove the two 4mm screws indicated by the M2.5X4 using the J00 tip screwdriver.
      • Remove SD card cap by just sliding out to reveal one screw.
      Ask FixBot
    4. HP Elitebook 820 G1 Monitor Display Replacement: step 8, image 1 of 1
      • Remove the two 3mm screws indicated by the M2.03 using the J00 tip screwdriver.
      • Remove the 4mm SD card screw using the J00 tip.
      Ask FixBot
    5. HP Elitebook 820 G1 Monitor Display Replacement: step 9, image 1 of 1
      • Remove the one 4mm fan screw using the J00 tip screwdriver.
      • Remove screw and metal plate to expose ribbon cable connector.
      Ask FixBot
    6. HP Elitebook 820 G1 Monitor Display Replacement: step 10, image 1 of 1
      • Use an opening tool to pry up the ribbon connector to disconnect.
      Ask FixBot
    7. HP Elitebook 820 G1 Monitor Display Replacement: step 11, image 1 of 1
      • Turn laptop over back to normal position as shown in the image.
      • Use opening tools to pry up keyboard.
      • When prying up keyboard, be sure to start near any corner of the keyboard.
      • There are two ribbon cables that must be disconnected before fully removing keyboard.
      Ask FixBot
    8. HP Elitebook 820 G1 Monitor Display Replacement: step 12, image 1 of 3 HP Elitebook 820 G1 Monitor Display Replacement: step 12, image 2 of 3 HP Elitebook 820 G1 Monitor Display Replacement: step 12, image 3 of 3
      • Carefully lift keyboard on one side to expose the two ribbon cables.
      • Use an opening tool to lift up the locking clip and unplug the two ribbon cables.
      Ask FixBot
    9. HP Elitebook 820 G1 Monitor Display Replacement: step 13, image 1 of 1
      • Remove the two 4mm screws centered notated by the keyboard logo using the J00 tip.
      Ask FixBot
    10. HP Elitebook 820 G1 Monitor Display Replacement: step 14, image 1 of 3 HP Elitebook 820 G1 Monitor Display Replacement: step 14, image 2 of 3 HP Elitebook 820 G1 Monitor Display Replacement: step 14, image 3 of 3
      • Once keyboard has been fully removed, the system case containing the motherboard can be lifted out easily.
      • The display is connected to the shell of the laptop.
      Ask FixBot
    11. HP Elitebook 820 G1 Monitor Display Replacement: step 15, image 1 of 1
      • Unplug fan cable by pulling away from its connector.
      Ask FixBot
    12. HP Elitebook 820 G1 Monitor Display Replacement: step 16, image 1 of 1
      • Unscrew the two 6mm fan screws using the J00 tip.
      • Fan screws are encased in springs and cannot be removed.
      Ask FixBot
    1. HP Elitebook 820 G1 Monitor Display Replacement, Monitor display: step 17, image 1 of 1
      • Retrieve the monitor display connected to the plastic chassis.
      Ask FixBot
    2. HP Elitebook 820 G1 Monitor Display Replacement: step 18, image 1 of 1
      • Unscrew the two 4mm hinge screws using the Philips 00 tip screwdriver.
      Ask FixBot
    3. HP Elitebook 820 G1 Monitor Display Replacement: step 19, image 1 of 1
      • Unhinge the monitor display from the chassis.
      Ask FixBot
Alberto Carlos Perez
431 Reputation
2 Guides authored
USF Tampa, Team S5-G1, Eyestone Spring 2018 Member of USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Members
48 Guides authored
1 Guide Comment
Hello,
I need to replace the inverter as my screen is too much dark.
I cannot see the inverter and even I cannot find any inverter for this model.
Do you know how to access to this inverter? Is it embedded within the screen?
Thanks by advance.
BR
richard P - Reply Share
Past 24 Hours: 7
Past 7 Days: 27
Past 30 Days: 101
All Time: 4,259
