HP Elitebook 820 G1 Keyboard Replacement
    1. HP Elitebook 820 G1 Keyboard Replacement, Battery: step 1, image 1 of 1
      • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
      • Turn over laptop so that the bottom is showing.
      • Unlock the latch.
      Ask FixBot
    2. HP Elitebook 820 G1 Keyboard Replacement: step 2, image 1 of 1
      • Remove the back cover and you will then be able to see the battery.
      Ask FixBot
    3. HP Elitebook 820 G1 Keyboard Replacement: step 3, image 1 of 1
      • Unlatch the two latches securing the battery in the case.
      Ask FixBot
    4. HP Elitebook 820 G1 Keyboard Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to lift and remove the battery.
      Ask FixBot
    1. HP Elitebook 820 G1 Keyboard Replacement, Keyboard: step 5, image 1 of 1
      • Remove the two Phillips #0 screws securing the keyboard to the laptop.
      • Turn the laptop over and lift the display to reveal the keyboard.
      Ask FixBot
    2. HP Elitebook 820 G1 Keyboard Replacement: step 6, image 1 of 1
      • Insert the plastic spudger between the keyboard and the housing.
      • Start at the corner.
      Ask FixBot
    3. HP Elitebook 820 G1 Keyboard Replacement: step 7, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 7, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 7, image 3 of 3
      • 4 tabs are located at the top of the keyboard, which lock it in place.
      • Pry and twist the spudger along the top of the keyboard until each tab is released.
      Ask FixBot
    4. HP Elitebook 820 G1 Keyboard Replacement: step 8, image 1 of 1
      • Pull back the keyboard from the top.
      • Be mindful of the fragile cables behind it.
      Ask FixBot
    5. HP Elitebook 820 G1 Keyboard Replacement: step 9, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 9, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 9, image 3 of 3
      • Flip up the connecting flap on each of the three ribbon cables.
      • The small cable on the last picture ist only there, if you have a backlit keyboard. If you want to replace a keyboard without backlight, there will be no cable on your original keyboard.
      Ask FixBot
    6. HP Elitebook 820 G1 Keyboard Replacement: step 10, image 1 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 10, image 2 of 3 HP Elitebook 820 G1 Keyboard Replacement: step 10, image 3 of 3
      • Remove each of the three cables by gently pulling them from their respective connectors.
      Ask FixBot
    7. HP Elitebook 820 G1 Keyboard Replacement: step 11, image 1 of 1
      • Remove the keyboard from the housing.
      Ask FixBot
6 other people completed this guide.
Lauren Vance
442 Reputation
2 Guides authored
IUPUI, Team S1-G2, Harley Fall 2018 Member of IUPUI, Team S1-G2, Harley Fall 2018
IUPUI-HARLEY-F18S1G2
2 Members
24 Guides authored
2 Guide Comments
Good guide. Thanks!
But you missed step 1. Remove two screws that hold the keyboard in place
Chris Maschmeier - Reply Share
@eth0wookiee do you mean is Step #5 ?
kardjo - Reply Share
Past 24 Hours: 1
Past 7 Days: 20
Past 30 Days: 101
All Time: 12,561
