HP Elitebook 820 G1 Hard Drive Replacement
    1. HP Elitebook 820 G1 Hard Drive Replacement, Battery: step 1, image 1 of 1
      • Ensure the laptop is completely powered off and power adapter is unplugged before removing the battery.
      • Turn over laptop so that the bottom is showing.
      • Unlock the latch.
      Ask FixBot
    2. HP Elitebook 820 G1 Hard Drive Replacement: step 2, image 1 of 1
      • Remove the back cover and you will then be able to see the battery.
      Ask FixBot
    3. HP Elitebook 820 G1 Hard Drive Replacement: step 3, image 1 of 1
      • Unlatch the two latches securing the battery in the case.
      Ask FixBot
    4. HP Elitebook 820 G1 Hard Drive Replacement: step 4, image 1 of 1
      • Use a plastic opening tool to lift and remove the battery.
      Ask FixBot
    1. HP Elitebook 820 G1 Hard Drive Replacement, Hard Drive: step 5, image 1 of 1
      • Remove the four 8mm screws with the T7 philip's head.
      Ask FixBot
    2. HP Elitebook 820 G1 Hard Drive Replacement: step 6, image 1 of 1
      • Remove the hard drive casing.
      • Unscrew the four 8mm Philips screws holding the hard drive.
      Ask FixBot
    3. HP Elitebook 820 G1 Hard Drive Replacement: step 7, image 1 of 1
      • Remove the hard drive from the casing and replace it.
      Ask FixBot
3 other people completed this guide.
Alberto Carlos Perez
431 Reputation
2 Guides authored
USF Tampa, Team S5-G1, Eyestone Spring 2018 Member of USF Tampa, Team S5-G1, Eyestone Spring 2018
USFT-EYESTONE-S18S5G1
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 53
All Time: 4,730
