HP Elitebook 6930p RAM (Expansion Slot) Replacement
    1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: step 1, image 1 of 3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: step 1, image 2 of 3 HP Elitebook 6930p RAM (Expansion Slot) Replacement, Battery Removal: step 1, image 3 of 3
      • Flip laptop over and locate the battery release button
      • Push release button to the left to release battery and gently pull battery from the laptop
      Ask FixBot
    1. HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): step 2, image 1 of 2 HP Elitebook 6930p RAM (Expansion Slot) Replacement, RAM (Expansion Slot): step 2, image 2 of 2
      • Locate the RAM expansion slot cover on the bottom of the laptop
      • Loosen the PM2.0×5.0 captive screw and remove the cover.
      Ask FixBot
    2. HP Elitebook 6930p RAM (Expansion Slot) Replacement: step 3, image 1 of 2 HP Elitebook 6930p RAM (Expansion Slot) Replacement: step 3, image 2 of 2
      • Install RAM module into the RAM slot on an angle of around 30 degrees
      • Press the RAM module down with your fingers on each corner until it clicks into the 2 metal clips and is locked down
      • Check to ensure the metal tabs are holding the RAM module down on both sides
      • Reinstall the RAM cover
      Ask FixBot
9 other people completed this guide.
Richdave
32,882 Reputation
30 Guides authored
Master Techs Member of Master Techs
Community
334 Members
8,251 Guides authored
17 Guide Comments
What kind of RAM do you place in this slot?
I want to upgrade my notebook, maybe with some RAM from ebay, so, What should I buy?
Jan Cerenohorsky - Reply Share
Also, is there already any RAM by default? What is the maximum capacity you can upgrade to?
Yes under the Keyboard and the Max is 8GB DDR2 6400
dcliddle - Reply Share
Can you add an 8GB DDR2 6400 to your laptop (HP6930p) without upgrading or changing the factory installed one? The label on the bottom of mine says C2D P8700 2.53 GHz 4GB.
Thanks for any help!
Brian Fenech - Reply Share
Thank you for information.
By p8slot.com
sutep Fifa - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 52
All Time: 16,858
