HP Elitebook 2740p Screen Replacement
    1. HP Elitebook 2740p Screen Replacement, Battery: step 1, image 1 of 1
      • Slide the lock tab to the right.
      Ask FixBot
    2. HP Elitebook 2740p Screen Replacement: step 2, image 1 of 1
      • Lift and remove the battery from the battery compartment.
      Ask FixBot
    1. HP Elitebook 2740p Screen Replacement, Screen: step 3, image 1 of 3 HP Elitebook 2740p Screen Replacement, Screen: step 3, image 2 of 3 HP Elitebook 2740p Screen Replacement, Screen: step 3, image 3 of 3
      • Locate the radio antenna on the right side of the top edge of the screen. Slide the latch to release the antenna.
      • Use a Phillips #0 screwdriver to remove the two 4 mm screws recessed in the antenna housing.
      Ask FixBot
    2. HP Elitebook 2740p Screen Replacement: step 4, image 1 of 3 HP Elitebook 2740p Screen Replacement: step 4, image 2 of 3 HP Elitebook 2740p Screen Replacement: step 4, image 3 of 3
      • Use a metal spudger to separate bezel from laptop body. there are tabs holding the bezel on along the entire bezel.
      • Pay special attention to the hinge cover at the bottom. It has tabs at both the top and bottom.
      • Remove the bezel from the laptop.
      Ask FixBot
    3. HP Elitebook 2740p Screen Replacement: step 5, image 1 of 3 HP Elitebook 2740p Screen Replacement: step 5, image 2 of 3 HP Elitebook 2740p Screen Replacement: step 5, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the eight 4 mm screws that hold the frame of the screen in place.
      • Use a Phillips #00 screwdriver to remove the single 3 mm screw at the corner of the frame.
      Ask FixBot
    4. HP Elitebook 2740p Screen Replacement: step 6, image 1 of 3 HP Elitebook 2740p Screen Replacement: step 6, image 2 of 3 HP Elitebook 2740p Screen Replacement: step 6, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the two 4 mm screws that hold the tilt button in place.
      • Remove the tilt button.
      Ask FixBot
    5. HP Elitebook 2740p Screen Replacement: step 7, image 1 of 3 HP Elitebook 2740p Screen Replacement: step 7, image 2 of 3 HP Elitebook 2740p Screen Replacement: step 7, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the three screws that secure the tablet-mode button board.
      • Disconnect the two blue ribbon cables and gently pull them free.
      • Remove the PCB board from the screen housing.
      Ask FixBot
    6. HP Elitebook 2740p Screen Replacement: step 8, image 1 of 3 HP Elitebook 2740p Screen Replacement: step 8, image 2 of 3 HP Elitebook 2740p Screen Replacement: step 8, image 3 of 3
      • Remove the gray rubber pad at the top of the screen next to the camera.
      • Remove the 3mm screw with a Phillips #0 screwdriver
      • Carefully tilt the screen down onto the keayboard
      Ask FixBot
    7. HP Elitebook 2740p Screen Replacement: step 9, image 1 of 2 HP Elitebook 2740p Screen Replacement: step 9, image 2 of 2
      • Fold the protective foil back from the ribbon cables.
      Ask FixBot
    8. HP Elitebook 2740p Screen Replacement: step 10, image 1 of 3 HP Elitebook 2740p Screen Replacement: step 10, image 2 of 3 HP Elitebook 2740p Screen Replacement: step 10, image 3 of 3
      • Unseat display ribbon cables.
      • Ribbon cables are secured with tape. Do not force the cables out of their sockets.
      • Remove the screen.
      Ask FixBot
4 other people completed this guide.
Joseph Hazel
353 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 63
All Time: 1,957
