Up to 20% off select tools
HP Elitebook 2740p RAM Replacement
Views: 1.4K
View statistics:
Past 24 Hours:
5
Past 7 Days:
14
Past 30 Days:
59
All Time:
1,408
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 3 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
The computers RAM, or Random Access Memory, is important in helping your computer run quickly and efficiently. Replacing damaged RAM or simply upgrading to newer/faster RAM is very beneficial to extending a computers life.
    1. HP Elitebook 2740p RAM Replacement, RAM: step 1, image 1 of 1
      • Place the laptop face down in front of you.
      • Use a Phillips #0 screwdriver to remove the three 3 mm screws from the back of the case.
      • Remove the back panel.
      Ask FixBot
    2. HP Elitebook 2740p RAM Replacement: step 2, image 1 of 3 HP Elitebook 2740p RAM Replacement: step 2, image 2 of 3 HP Elitebook 2740p RAM Replacement: step 2, image 3 of 3
      • Press outward on the plastic clips to release the RAM.
      • Gently pull the RAM stick out of the SODIMM slot.
      Ask FixBot
    3. HP Elitebook 2740p RAM Replacement: step 3, image 1 of 2 HP Elitebook 2740p RAM Replacement: step 3, image 2 of 2
      • Repeat step 2 for the second stick of RAM and remove it.
      Ask FixBot
2 other people completed this guide.
Author
with
Cameron Whittle
467 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 59
All Time: 1,408
