HP ElitePad 900 LCD Replacement
    1. HP ElitePad 900 LCD Replacement, Front Panel Assembly: step 1, image 1 of 1
      • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
      Ask FixBot
    2. HP ElitePad 900 LCD Replacement: step 2, image 1 of 2 HP ElitePad 900 LCD Replacement: step 2, image 2 of 2
      • Use a suction cup to pull the display assembly up.
      Ask FixBot
    3. HP ElitePad 900 LCD Replacement: step 3, image 1 of 2 HP ElitePad 900 LCD Replacement: step 3, image 2 of 2
      • Use the tip of a spudger to disconnect the two display ZIF connectors.
      Ask FixBot
    1. HP ElitePad 900 LCD Replacement, LCD: step 4, image 1 of 3 HP ElitePad 900 LCD Replacement, LCD: step 4, image 2 of 3 HP ElitePad 900 LCD Replacement, LCD: step 4, image 3 of 3
      • Remove the four 1.6mm Phillips #000 screws securing the LCD to the digitizer.
      Ask FixBot
    2. HP ElitePad 900 LCD Replacement: step 5, image 1 of 1
      • Use the tip of a spudger to disconnect the ribbon cable ZIF connector.
      Ask FixBot
    3. HP ElitePad 900 LCD Replacement: step 6, image 1 of 3 HP ElitePad 900 LCD Replacement: step 6, image 2 of 3 HP ElitePad 900 LCD Replacement: step 6, image 3 of 3
      • Use a plastic opening tool to separate the LCD from the digitizer.
      Ask FixBot
2 other people completed this guide.
Kyle Marques
889 Reputation
6 Guides authored
USF Tampa, Team 12-4, Blackwell Fall 2015 Member of USF Tampa, Team 12-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G4
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 29
Past 30 Days: 48
All Time: 1,691
