HP EliteOne 800 G1 Removing Stand Replacement
  1. HP EliteOne 800 G1 Removing Stand Replacement, Removing Stand: step 1, image 1 of 2 HP EliteOne 800 G1 Removing Stand Replacement, Removing Stand: step 1, image 2 of 2
    • Press locking latch on the bottom of the base of the stand.
    • Pull the plastic cover off of the stand.
    Ask FixBot
  2. HP EliteOne 800 G1 Removing Stand Replacement: step 2, image 1 of 2 HP EliteOne 800 G1 Removing Stand Replacement: step 2, image 2 of 2
    • Use a Torx T15 driver and stick it through the holes on the stand in order to remove the two 12mm screws on the back of the main unit.
    • Tilt stand and lift up to remove it.
    Ask FixBot
  3. HP EliteOne 800 G1 Removing Stand Replacement: step 3, image 1 of 2 HP EliteOne 800 G1 Removing Stand Replacement: step 3, image 2 of 2
    • Use a Torx T15 driver to remove the single 10mm screw on the back panel.
    • Pull the back panel toward the bottom of the device to remove it.
    Ask FixBot
2 other people completed this guide.
Michael Ewing
1,071 Reputation
4 Guides authored
Cal Poly, Team 1-24, Maness Fall 2015 Member of Cal Poly, Team 1-24, Maness Fall 2015
CPSU-MANESS-F15S1G24
4 Members
14 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 54
All Time: 3,809
