HP EliteBook x360 830 G7 RAM Replacement
    1. HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: step 1, image 1 of 2 HP EliteBook x360 830 G7 RAM Replacement, Remove the backplate: step 1, image 2 of 2
      • Turn the computer over so the back is facing up.
      • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
      • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
      • Lift the backplate from the computer.
      Ask FixBot
    2. HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: step 2, image 1 of 3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: step 2, image 2 of 3 HP EliteBook x360 830 G7 RAM Replacement, Remove the shield: step 2, image 3 of 3
      • Gently lift the larger, rectangular metal shielding off. This shielding covers the RAM.
      Ask FixBot
    3. HP EliteBook x360 830 G7 RAM Replacement, Remove the RAM: step 3, image 1 of 1
      • Push down on the two latches on both sides of the RAM to release it.
      • This will allow you to remove the RAM and replace it with no issues.
      Ask FixBot
4 other people completed this guide.
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 129
All Time: 3,408
