HP EliteBook Folio G1 Solid State Drive Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
16
Past 30 Days:
82
All Time:
390
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 25 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
This guide covers the replacement of the solid state drive (SSD) in the HP EliteBook Folio G1.
The SSD stores your operating system, applications, and files, allowing for fast boot times and data access. If you experience frequent crashes, slow performance, or drive detection errors, the SSD may be failing and require replacement.
Following this guide will help you safely and effectively replace the SSD to restore fast, reliable storage performance.
Tools
    1. HP EliteBook Folio G1 Solid State Drive Replacement, Back Case: step 1, image 1 of 1
      • Shut down the laptop completely and close the lid.
      Ask FixBot
    2. HP EliteBook Folio G1 Solid State Drive Replacement: step 2, image 1 of 1
      • Turn the laptop upside down so the bottom panel is facing up.
      • Position the device so the QR code and text details are readable and facing you.
      Ask FixBot
    3. HP EliteBook Folio G1 Solid State Drive Replacement: step 3, image 1 of 1
      • Remove the eight 3.0 mm screws securing the back case using a T5 Torx screwdriver.
      Ask FixBot
    4. HP EliteBook Folio G1 Solid State Drive Replacement: step 4, image 1 of 3 HP EliteBook Folio G1 Solid State Drive Replacement: step 4, image 2 of 3 HP EliteBook Folio G1 Solid State Drive Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool or spudger into the seam between the bottom cover and the chassis.
      • Gently pry around the edges to release the retaining clips.
      • Carefully lift the back cover up and away from the laptop.
      Ask FixBot
    1. HP EliteBook Folio G1 Solid State Drive Replacement, Solid State Drive: step 5, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the one 3.0 mm screw securing the solid state drive.
      Ask FixBot
    2. HP EliteBook Folio G1 Solid State Drive Replacement: step 6, image 1 of 2 HP EliteBook Folio G1 Solid State Drive Replacement: step 6, image 2 of 2
      • Carefully lift the storage drive and slide it to the right to remove it.
      Ask FixBot
Groupe 3
339 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 16
Past 30 Days: 82
All Time: 390
