HP EliteBook Folio G1 Keyboard Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
91
All Time:
550
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 hours
Difficulty: Difficult
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Introduction
Go to step 1 ↓
This guide covers the replacement of the keyboard on the HP EliteBook Folio G1.
The keyboard is the primary input device for typing and system control. This guide is meant to assist the process of replacing the physical keyboard for a HP EliteBook Folio G1, in the case that troubleshooting does not solve the issue(s) found/diagnosed.
Following this guide will help you safely and effectively replace the keyboard to restore full typing functionality.
There are a total of 48 (3mm) screws that will need to be removed in the process (20 outside, 28 inside).
Tools
    1. HP EliteBook Folio G1 Keyboard Replacement, Back Case: step 1, image 1 of 1
      • Shut down the laptop completely and close the lid.
      Ask FixBot
    2. HP EliteBook Folio G1 Keyboard Replacement: step 2, image 1 of 1
      • Turn the laptop upside down so the bottom panel is facing up.
      • Position the device so the QR code and text details are readable and facing you.
      Ask FixBot
    3. HP EliteBook Folio G1 Keyboard Replacement: step 3, image 1 of 1
      • Remove the eight 3.0 mm screws securing the back case using a T5 Torx screwdriver.
      Ask FixBot
    4. HP EliteBook Folio G1 Keyboard Replacement: step 4, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 4, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool or spudger into the seam between the bottom cover and the chassis.
      • Gently pry around the edges to release the retaining clips.
      • Carefully lift the back cover up and away from the laptop.
      Ask FixBot
    1. HP EliteBook Folio G1 Keyboard Replacement, Solid State Drive: step 5, image 1 of 1
      • Using a Phillips #0 screwdriver, remove the one 3.0 mm screw securing the solid state drive.
      Ask FixBot
    2. HP EliteBook Folio G1 Keyboard Replacement: step 6, image 1 of 2 HP EliteBook Folio G1 Keyboard Replacement: step 6, image 2 of 2
      • Carefully lift the storage drive and slide it to the right to remove it.
      Ask FixBot
    1. HP EliteBook Folio G1 Keyboard Replacement, Audio Jack Port: step 7, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement, Audio Jack Port: step 7, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement, Audio Jack Port: step 7, image 3 of 3
      • Use an opening tool or your fingernail to carefully lift the small locking flap on the audio board cable connector.
      Ask FixBot
    2. HP EliteBook Folio G1 Keyboard Replacement: step 8, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 8, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 8, image 3 of 3
      • Gently pull the ribbon cable straight out of the connector to disconnect the audio board from the motherboard.
      Ask FixBot
    3. HP EliteBook Folio G1 Keyboard Replacement: step 9, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 9, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 9, image 3 of 3
      • Using a Phillips #00 screwdriver, remove the two 3.0 mm screws securing the audio board to the chassis.
      Ask FixBot
    4. HP EliteBook Folio G1 Keyboard Replacement: step 10, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 10, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 10, image 3 of 3
      • Avoid bending or twisting the board, as it and the connectors are fragile.
      • Use a opening tool to gently lift the audio board straight upward from its seated position.
      Ask FixBot
    1. HP EliteBook Folio G1 Keyboard Replacement, Speakers: step 11, image 1 of 2 HP EliteBook Folio G1 Keyboard Replacement, Speakers: step 11, image 2 of 2
      • The cable is extremely fragile. Handle it carefully to avoid damage.
      • Locate the speaker cable connecting to the motherboard on the top right and carefully pull down to remove.
      Ask FixBot
    2. HP EliteBook Folio G1 Keyboard Replacement: step 12, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the six 3.0 mm screws securing the speakers.
      Ask FixBot
    3. HP EliteBook Folio G1 Keyboard Replacement: step 13, image 1 of 1
      • Detach the tape that holds the cables from the battery and touchpad.
      Ask FixBot
    4. HP EliteBook Folio G1 Keyboard Replacement: step 14, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 14, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 14, image 3 of 3
      • Insert an opening tool under the speaker and gently lift it out of its slot.
      Ask FixBot
    1. HP EliteBook Folio G1 Keyboard Replacement, Battery: step 15, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement, Battery: step 15, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement, Battery: step 15, image 3 of 3
      • Remove the six 3.0 mm screws securing the battery using a Phillips #0 screwdriver.
      • Remove the two 3.0 mm screws securing the battery using a JIS #000 screwdriver.
      Ask FixBot
    2. HP EliteBook Folio G1 Keyboard Replacement: step 16, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 16, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 16, image 3 of 3
      • Be careful to not puncture the battery during the process.
      • After removing the screws, pry and lift the battery out.
      Ask FixBot
    1. HP EliteBook Folio G1 Keyboard Replacement, Motherboard: step 17, image 1 of 2 HP EliteBook Folio G1 Keyboard Replacement, Motherboard: step 17, image 2 of 2
      • Disconnect the Wi-Fi antenna cable.
      Ask FixBot
    2. HP EliteBook Folio G1 Keyboard Replacement: step 18, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 18, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 18, image 3 of 3
      • Disconnect the display cable.
      Ask FixBot
    3. HP EliteBook Folio G1 Keyboard Replacement: step 19, image 1 of 2 HP EliteBook Folio G1 Keyboard Replacement: step 19, image 2 of 2
      • Disconnect the keyboard cable.
      Ask FixBot
    4. HP EliteBook Folio G1 Keyboard Replacement: step 20, image 1 of 2 HP EliteBook Folio G1 Keyboard Replacement: step 20, image 2 of 2
      • It is important to be careful in the disconnecting of ribbon cables. Gently use the prying tool if need be.
      • Disconnect the webcam cable.
      Ask FixBot
    5. HP EliteBook Folio G1 Keyboard Replacement: step 21, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 21, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 21, image 3 of 3
      • Grab and peel this sticker upwards and off; this is the touchpad cable.
      Ask FixBot
    6. HP EliteBook Folio G1 Keyboard Replacement: step 22, image 1 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 22, image 2 of 3 HP EliteBook Folio G1 Keyboard Replacement: step 22, image 3 of 3
      • Lift the motherboard out of the laptop.
      Ask FixBot
    1. HP EliteBook Folio G1 Keyboard Replacement, Keyboard: step 23, image 1 of 1
      • Remove the 48 3.0 mm JIS #000 screws securing the keyboard.
      Ask FixBot
    2. HP EliteBook Folio G1 Keyboard Replacement: step 24, image 1 of 2 HP EliteBook Folio G1 Keyboard Replacement: step 24, image 2 of 2
      • Use a plastic opening tool to carefully lift and separate the keyboard from the laptop shell.
      Ask FixBot
    3. HP EliteBook Folio G1 Keyboard Replacement: step 25, image 1 of 2 HP EliteBook Folio G1 Keyboard Replacement: step 25, image 2 of 2
      • Carefully lift the keyboard from the laptop chassis, ensuring no ribbon cables or connectors are strained or damaged.
      Ask FixBot
Mateya Elez
329 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 91
All Time: 550
