HP EliteBook Folio G1 Battery Replacement
    1. HP EliteBook Folio G1 Battery Replacement, Back Case: step 1, image 1 of 1
      • Shut down the laptop completely and close the lid.
      Ask FixBot
    2. HP EliteBook Folio G1 Battery Replacement: step 2, image 1 of 1
      • Turn the laptop upside down so the bottom panel is facing up.
      • Position the device so the QR code and text details are readable and facing you.
      Ask FixBot
    3. HP EliteBook Folio G1 Battery Replacement: step 3, image 1 of 1
      • Remove the eight 3.0 mm screws securing the back case using a T5 Torx screwdriver.
      Ask FixBot
    4. HP EliteBook Folio G1 Battery Replacement: step 4, image 1 of 3 HP EliteBook Folio G1 Battery Replacement: step 4, image 2 of 3 HP EliteBook Folio G1 Battery Replacement: step 4, image 3 of 3
      • Insert a plastic opening tool or spudger into the seam between the bottom cover and the chassis.
      • Gently pry around the edges to release the retaining clips.
      • Carefully lift the back cover up and away from the laptop.
      Ask FixBot
    1. HP EliteBook Folio G1 Battery Replacement, Battery: step 5, image 1 of 3 HP EliteBook Folio G1 Battery Replacement, Battery: step 5, image 2 of 3 HP EliteBook Folio G1 Battery Replacement, Battery: step 5, image 3 of 3
      • Remove the six 3.0 mm screws securing the battery using a Phillips #0 screwdriver.
      • Remove the two 3.0 mm screws securing the battery using a JIS #000 screwdriver.
      Ask FixBot
    2. HP EliteBook Folio G1 Battery Replacement: step 6, image 1 of 3 HP EliteBook Folio G1 Battery Replacement: step 6, image 2 of 3 HP EliteBook Folio G1 Battery Replacement: step 6, image 3 of 3
      • Be careful to not puncture the battery during the process.
      • After removing the screws, pry and lift the battery out.
      Ask FixBot
Quentin Cannistra
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 66
All Time: 436
