HP EliteBook 8560w Memory Replacement
    1. HP EliteBook 8560w Memory Replacement, Battery: step 1, image 1 of 2 HP EliteBook 8560w Memory Replacement, Battery: step 1, image 2 of 2
      • Make sure your device is powered off and disconnected from the power adapter.
      • Slide the lock all the way to the left. The battery should pop up.
      Ask FixBot
    2. HP EliteBook 8560w Memory Replacement: step 2, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. HP EliteBook 8560w Memory Replacement, Back Panel: step 3, image 1 of 2 HP EliteBook 8560w Memory Replacement, Back Panel: step 3, image 2 of 2
      • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
      • Make sure your device is turned off and your battery is removed.
      Ask FixBot
    2. HP EliteBook 8560w Memory Replacement: step 4, image 1 of 1
      • Slide the panel towards you and lift it up to open and access the back of the computer.
      Ask FixBot
    1. HP EliteBook 8560w Memory Replacement, CD/DVD ROM: step 5, image 1 of 2 HP EliteBook 8560w Memory Replacement, CD/DVD ROM: step 5, image 2 of 2
      • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
      • The screw does not have to come out completely.
      Ask FixBot
    2. HP EliteBook 8560w Memory Replacement: step 6, image 1 of 3 HP EliteBook 8560w Memory Replacement: step 6, image 2 of 3 HP EliteBook 8560w Memory Replacement: step 6, image 3 of 3
      • Push the metal tip to the left with a screwdriver.
      Ask FixBot
    3. HP EliteBook 8560w Memory Replacement: step 7, image 1 of 2 HP EliteBook 8560w Memory Replacement: step 7, image 2 of 2
      • Pull out the CD/DVD ROM with your hand.
      Ask FixBot
    1. HP EliteBook 8560w Memory Replacement, Keyboard: step 8, image 1 of 1
      • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
      Ask FixBot
    2. HP EliteBook 8560w Memory Replacement: step 9, image 1 of 3 HP EliteBook 8560w Memory Replacement: step 9, image 2 of 3 HP EliteBook 8560w Memory Replacement: step 9, image 3 of 3
      • Put your finger through the hole to push out the keyboard from its place.
      • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
      Ask FixBot
    3. HP EliteBook 8560w Memory Replacement: step 10, image 1 of 3 HP EliteBook 8560w Memory Replacement: step 10, image 2 of 3 HP EliteBook 8560w Memory Replacement: step 10, image 3 of 3
      • Carefully lift keyboard to reveal connection strips.
      • Unlock the latch holding the connection strips.
      • Pull out the connection strips from the motherboard.
      Ask FixBot
    1. HP EliteBook 8560w Memory Replacement, Memory: step 11, image 1 of 3 HP EliteBook 8560w Memory Replacement, Memory: step 11, image 2 of 3 HP EliteBook 8560w Memory Replacement, Memory: step 11, image 3 of 3
      • Your HP EliteBook 8560w has two pairs of RAM: one below the keyboard and the other below the back panel. This guide begins removing the pair below the keyboard, then proceeds to the one below the back panel.
      • Pull both metal parts away from memory pair. Lift memory pair and it will come out.
      Ask FixBot
    2. HP EliteBook 8560w Memory Replacement: step 12, image 1 of 3 HP EliteBook 8560w Memory Replacement: step 12, image 2 of 3 HP EliteBook 8560w Memory Replacement: step 12, image 3 of 3
      • Flip device upside down. Pull metal bars away from the memory. Lift the memory up and it will pop out.
      Ask FixBot
2 Guide Comments
The best explanation to a memory replace ever! Congratulations!
Please! Do the same to a graphic card replace for HP 8560W!! Please..PLease...
And, I have a question: MAY I INSTALL AN MSATA HARD DISK ON WWAN SLOT from this machine HP 8560W Elitebook workstation??? May I?
l g - Reply Share
No, this doesn't work.
This "push rather hard" is the easiest way to damage your keyboard. It doesn’t work — be careful.
I tried to remove the keyboard carefully for about half an hour; the result was a damaged Insert key, and the keyboard still wouldn’t come off.
Thanks a lot, “experts”.
Ars Satanica - Reply Share
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 77
All Time: 2,829
