HP EliteBook 8560w Keyboard Replacement
    1. HP EliteBook 8560w Keyboard Replacement, Battery: step 1, image 1 of 2 HP EliteBook 8560w Keyboard Replacement, Battery: step 1, image 2 of 2
      • Make sure your device is powered off and disconnected from the power adapter.
      • Slide the lock all the way to the left. The battery should pop up.
      Ask FixBot
    2. HP EliteBook 8560w Keyboard Replacement: step 2, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. HP EliteBook 8560w Keyboard Replacement, Back Panel: step 3, image 1 of 2 HP EliteBook 8560w Keyboard Replacement, Back Panel: step 3, image 2 of 2
      • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
      • Make sure your device is turned off and your battery is removed.
      Ask FixBot
    2. HP EliteBook 8560w Keyboard Replacement: step 4, image 1 of 1
      • Slide the panel towards you and lift it up to open and access the back of the computer.
      Ask FixBot
    1. HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: step 5, image 1 of 2 HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: step 5, image 2 of 2
      • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
      • The screw does not have to come out completely.
      Ask FixBot
    2. HP EliteBook 8560w Keyboard Replacement: step 6, image 1 of 3 HP EliteBook 8560w Keyboard Replacement: step 6, image 2 of 3 HP EliteBook 8560w Keyboard Replacement: step 6, image 3 of 3
      • Push the metal tip to the left with a screwdriver.
      Ask FixBot
    3. HP EliteBook 8560w Keyboard Replacement: step 7, image 1 of 2 HP EliteBook 8560w Keyboard Replacement: step 7, image 2 of 2
      • Pull out the CD/DVD ROM with your hand.
      Ask FixBot
    1. HP EliteBook 8560w Keyboard Replacement, Keyboard: step 8, image 1 of 1
      • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
      Ask FixBot
    2. HP EliteBook 8560w Keyboard Replacement: step 9, image 1 of 3 HP EliteBook 8560w Keyboard Replacement: step 9, image 2 of 3 HP EliteBook 8560w Keyboard Replacement: step 9, image 3 of 3
      • Put your finger through the hole to push out the keyboard from its place.
      • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
      Ask FixBot
    3. HP EliteBook 8560w Keyboard Replacement: step 10, image 1 of 3 HP EliteBook 8560w Keyboard Replacement: step 10, image 2 of 3 HP EliteBook 8560w Keyboard Replacement: step 10, image 3 of 3
      • Carefully lift keyboard to reveal connection strips.
      • Unlock the latch holding the connection strips.
      • Pull out the connection strips from the motherboard.
      Ask FixBot
3 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 62
All Time: 2,128
