Introduction
Go to step 1 ↓Hello, this guide will help you replace the Hard Drive in a HP EliteBook 8560w.
Keep in mind that your device should be turned off and disconnected from the power adapter.
Usually, a Hard Drive needs to be replaced when the computer won’t boot. However, check out our troubleshooting page to see if your issue falls into a different category.
Please follow instructions as they appear.
Fix Kit
This kit contains all the parts and tools needed to complete this guide.
Parts
Tools
Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
Remove the four M2.5x8mm screws with Phillips #0 screwdriver and lift up the panel to access your Hard Drive.
