HP EliteBook 8560w CD/DVD ROM Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
61
All Time:
1,055
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
This guide will help you replace the CD/DVD ROM in a HP EliteBook 8560w.
Keep in mind that the computer’s battery needs to be removed and the power adapter must be disconnected before you begin. We’ll show you how to do that in this guide as well.
Usually, a computer’s CD/DVD ROM needs to be replaced when you insert a CD or a DVD and it doesn’t play. However, check out our troubleshooting page to see if your problem falls into a different category.
Please follow instructions as they appear.
Tools
    1. HP EliteBook 8560w CD/DVD ROM Replacement, Battery: step 1, image 1 of 2 HP EliteBook 8560w CD/DVD ROM Replacement, Battery: step 1, image 2 of 2
      • Make sure your device is powered off and disconnected from the power adapter.
      • Slide the lock all the way to the left. The battery should pop up.
      Ask FixBot
    2. HP EliteBook 8560w CD/DVD ROM Replacement: step 2, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: step 3, image 1 of 2 HP EliteBook 8560w CD/DVD ROM Replacement, Back Panel: step 3, image 2 of 2
      • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
      • Make sure your device is turned off and your battery is removed.
      Ask FixBot
    2. HP EliteBook 8560w CD/DVD ROM Replacement: step 4, image 1 of 1
      • Slide the panel towards you and lift it up to open and access the back of the computer.
      Ask FixBot
    1. HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: step 5, image 1 of 2 HP EliteBook 8560w CD/DVD ROM Replacement, CD/DVD ROM: step 5, image 2 of 2
      • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
      • The screw does not have to come out completely.
      Ask FixBot
    2. HP EliteBook 8560w CD/DVD ROM Replacement: step 6, image 1 of 3 HP EliteBook 8560w CD/DVD ROM Replacement: step 6, image 2 of 3 HP EliteBook 8560w CD/DVD ROM Replacement: step 6, image 3 of 3
      • Push the metal tip to the left with a screwdriver.
      Ask FixBot
    3. HP EliteBook 8560w CD/DVD ROM Replacement: step 7, image 1 of 2 HP EliteBook 8560w CD/DVD ROM Replacement: step 7, image 2 of 2
      • Pull out the CD/DVD ROM with your hand.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 61
All Time: 1,055
