HP EliteBook 8560w Back Panel Replacement
    1. HP EliteBook 8560w Back Panel Replacement, Battery: step 1, image 1 of 2 HP EliteBook 8560w Back Panel Replacement, Battery: step 1, image 2 of 2
      • Make sure your device is powered off and disconnected from the power adapter.
      • Slide the lock all the way to the left. The battery should pop up.
      Ask FixBot
    2. HP EliteBook 8560w Back Panel Replacement: step 2, image 1 of 1
      • Pull the battery out.
      Ask FixBot
    1. HP EliteBook 8560w Back Panel Replacement, Back Panel: step 3, image 1 of 2 HP EliteBook 8560w Back Panel Replacement, Back Panel: step 3, image 2 of 2
      • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
      • Make sure your device is turned off and your battery is removed.
      Ask FixBot
    2. HP EliteBook 8560w Back Panel Replacement: step 4, image 1 of 1
      • Slide the panel towards you and lift it up to open and access the back of the computer.
      Ask FixBot
Finish Line
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 57
All Time: 2,100
