HP EliteBook 8530w Screen Replacement
    1. HP EliteBook 8530w Screen Replacement, Battery: step 1, image 1 of 2 HP EliteBook 8530w Screen Replacement, Battery: step 1, image 2 of 2
      • Turn the laptop off then place it down so that the back is facing up.
      • Slide the battery release switch to the left and hold it there.
      Ask FixBot
    2. HP EliteBook 8530w Screen Replacement: step 2, image 1 of 2 HP EliteBook 8530w Screen Replacement: step 2, image 2 of 2
      • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
      • Once the battery is removed from the laptop, you may release the switch.
      • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
      Ask FixBot
    1. HP EliteBook 8530w Screen Replacement, Screen: step 3, image 1 of 1
      • Turn the laptop off then place it down so that the top is facing up, then open the laptop.
      • Remove the six screws around the screen bezel using a Phillips #00 screwdriver.
      Ask FixBot
    2. HP EliteBook 8530w Screen Replacement: step 4, image 1 of 3 HP EliteBook 8530w Screen Replacement: step 4, image 2 of 3 HP EliteBook 8530w Screen Replacement: step 4, image 3 of 3
      • Using a plastic opening tool, gently pry the bezel from the screen on all four sides.
      • Remove the bezel.
      Ask FixBot
    3. HP EliteBook 8530w Screen Replacement: step 5, image 1 of 3 HP EliteBook 8530w Screen Replacement: step 5, image 2 of 3 HP EliteBook 8530w Screen Replacement: step 5, image 3 of 3
      • Lift the screen from the frame at the top of the laptop.
      • At the bottom of the screen, there will be a cable connected to the body of the laptop. Remove this cable.
      • On the back of the screen, there will be a ribbon cable that connects to it. Remove this cable by pinching the two tabs on the ends of the connector and pull outwards.
      Ask FixBot
    4. HP EliteBook 8530w Screen Replacement: step 6, image 1 of 3 HP EliteBook 8530w Screen Replacement: step 6, image 2 of 3 HP EliteBook 8530w Screen Replacement: step 6, image 3 of 3
      • The screen is being held in place by eight screws on the left and right side. Remove these eight screws with a Phillips #00 screwdriver.
      • These screws are the only thing holding the screen in place. Make sure you are holding the screen when you are removing the last few screws.
      • Remove the screen.
      Ask FixBot
2 Guide Comments
Hi! I have this laptop and i got a problem. Laptop starts but it's not showing nothing on the screen. If i remove the RAM memory i cannot here any sound from the motherboard so i think that the problem it is not in the screen and it's on the motherboard. What kind of test i could make to check my theory? Could be the BIOS too? Any help pls
Alvaro ConecTaller - Reply Share
Hi I have a similar laptop, the 8540w that I want to keep working with it's DreamColor screen, but the plastic tabs on the flat ribbon cable connector fell apart. Do you recommend using a solder iron to remove and then replace the connector or could a non-conductive polymide tape work to hold the ribbon in place? It's disappointing that plastic deteriorates, otherwise, it's a functional laptop.
Ros - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 62
All Time: 1,186
