Up to 20% off select tools
HP EliteBook 8530w Fan Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
2
Past 7 Days:
10
Past 30 Days:
74
All Time:
1,245
Comments: 6
6 comments on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 35 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
If your device is frequently overheating or making excessive noise, especially during compute intensive tasks, it may be due to a malfunctioning or dirty fan. This guide will show you how to replace the fan in the HP EliteBook 8530w laptop in the hopes of alleviating these issues.
    1. HP EliteBook 8530w Fan Replacement, Battery: step 1, image 1 of 2 HP EliteBook 8530w Fan Replacement, Battery: step 1, image 2 of 2
      • Turn the laptop off then place it down so that the back is facing up.
      • Slide the battery release switch to the left and hold it there.
      Ask FixBot
    2. HP EliteBook 8530w Fan Replacement: step 2, image 1 of 2 HP EliteBook 8530w Fan Replacement: step 2, image 2 of 2
      • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
      • Once the battery is removed from the laptop, you may release the switch.
      • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
      Ask FixBot
    1. HP EliteBook 8530w Fan Replacement, Fan: step 3, image 1 of 1
      • Unscrew the two screws from the center panel with a Phillips #00 screwdriver.
      • These screws should have a keyboard icon stamped next to them.
      Ask FixBot
    2. HP EliteBook 8530w Fan Replacement: step 4, image 1 of 3 HP EliteBook 8530w Fan Replacement: step 4, image 2 of 3 HP EliteBook 8530w Fan Replacement: step 4, image 3 of 3
      • Flip the laptop over then open the lid.
      • Slide the four tabs at the top of the keyboard towards you with your finger.
      • Wedge a finger or spudger in the top corner of the keyboard and hinge it forward to reveal the backside.
      • Do not try to pull the keyboard out of the laptop. There are still cables connected to it that can easily be damaged.
      Ask FixBot
    3. HP EliteBook 8530w Fan Replacement: step 5, image 1 of 3 HP EliteBook 8530w Fan Replacement: step 5, image 2 of 3 HP EliteBook 8530w Fan Replacement: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Use a Torx TR7 screwdriver to remove the three screws holding down the fan.
      • Gently remove the fan connector that plugs into the motherboard.
      • Note: It can help to use something like tweezers to remove the connector if you are having trouble.
      • Remove the fan.
      Ask FixBot
Author
with
Raymond Kwasneski
511 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 74
All Time: 1,245
