HP EliteBook 8530w Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
18
Past 30 Days:
76
All Time:
963
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
This is a guide that will show you how to replace the battery of an HP EliteBook 8530w.
The battery of a laptop is the most common thing that needs replacing. Luckily, it is the easiest thing to replace for this laptop.
    1. HP EliteBook 8530w Battery Replacement, Battery: step 1, image 1 of 2 HP EliteBook 8530w Battery Replacement, Battery: step 1, image 2 of 2
      • Turn the laptop off then place it down so that the back is facing up.
      • Slide the battery release switch to the left and hold it there.
      Ask FixBot
    2. HP EliteBook 8530w Battery Replacement: step 2, image 1 of 2 HP EliteBook 8530w Battery Replacement: step 2, image 2 of 2
      • Pull the battery away upward and away from the laptop while continuing to hold the release switch.
      • Once the battery is removed from the laptop, you may release the switch.
      • To properly dispose of your battery, look for the closest location that accepts electronic waste in your area and drop it off there.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 76
All Time: 963
