HP EliteBook 850 G7 SSD Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
24
Past 30 Days:
115
All Time:
764
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
    1. HP EliteBook 850 G7 SSD Replacement, SSD: step 1, image 1 of 2 HP EliteBook 850 G7 SSD Replacement, SSD: step 1, image 2 of 2
      • To start flip the device so the bottom is facing up
      Ask FixBot
    2. HP EliteBook 850 G7 SSD Replacement: step 2, image 1 of 2 HP EliteBook 850 G7 SSD Replacement: step 2, image 2 of 2
      • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
      • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
      Ask FixBot
    3. HP EliteBook 850 G7 SSD Replacement: step 3, image 1 of 2 HP EliteBook 850 G7 SSD Replacement: step 3, image 2 of 2
      • Unscrew the marked screw
      • Pull the SSD out in the marked direction
      • It can be replaced with most NVME 2280 SSDs
      Ask FixBot
Caleb Pierce
1,344 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 24
Past 30 Days: 115
All Time: 764
