HP EliteBook 850 G7 RAM Replacement
    1. HP EliteBook 850 G7 RAM Replacement, RAM: step 1, image 1 of 2 HP EliteBook 850 G7 RAM Replacement, RAM: step 1, image 2 of 2
      • To start flip the device so the bottom is facing up
      Ask FixBot
    2. HP EliteBook 850 G7 RAM Replacement: step 2, image 1 of 2 HP EliteBook 850 G7 RAM Replacement: step 2, image 2 of 2
      • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
      • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
      Ask FixBot
    3. HP EliteBook 850 G7 RAM Replacement: step 3, image 1 of 3 HP EliteBook 850 G7 RAM Replacement: step 3, image 2 of 3 HP EliteBook 850 G7 RAM Replacement: step 3, image 3 of 3
      • Lift directly up on the marked tab to remove the shielding
      • The RAM is now exposed.
      • When reassembling make sure to realign the sides of the shielding with the clips on the motherboard
      Ask FixBot
      • The new RAM can be inserted and clipped down as shown.
      • For reference the 850 G7 uses DDR4 SODIMMs
      Ask FixBot
Caleb Pierce
1,344 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 19
Past 30 Days: 96
All Time: 468
