HP EliteBook 850 G7 Fan Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
13
Past 30 Days:
71
All Time:
382
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Parts
Tools
    1. HP EliteBook 850 G7 Fan Replacement, Fan: step 1, image 1 of 2 HP EliteBook 850 G7 Fan Replacement, Fan: step 1, image 2 of 2
      • To start flip the device so the bottom is facing up
      Ask FixBot
    2. HP EliteBook 850 G7 Fan Replacement: step 2, image 1 of 2 HP EliteBook 850 G7 Fan Replacement: step 2, image 2 of 2
      • Unscrew the 5 marked captive screws with a Phillips #1 and flip the device so the hinge is faced towards you
      • Slide a spudger under the shell to pop the clips and run it around the perimeter of the shell until you can remove it.
      Ask FixBot
    3. HP EliteBook 850 G7 Fan Replacement: step 3, image 1 of 3 HP EliteBook 850 G7 Fan Replacement: step 3, image 2 of 3 HP EliteBook 850 G7 Fan Replacement: step 3, image 3 of 3
      • Unplug both marked cables. For the larger one pull it straight up gently but firmly.
      • Pull the cables out of the channels.
      • Extremely gently remove the remaining cables from the channels
      • Unscrew the marked screws.
      Ask FixBot
    4. HP EliteBook 850 G7 Fan Replacement: step 4, image 1 of 2 HP EliteBook 850 G7 Fan Replacement: step 4, image 2 of 2
      • Be careful to only pull on the plastic end of the cable.
      • Using a pair of tweezers or a spudger pull the fan cable out
      • The fan can now be removed
      Ask FixBot
Caleb Pierce
1,344 Reputation
8 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 71
All Time: 382
