HP EliteBook 850 G5 Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
3
Past 7 Days:
54
Past 30 Days:
202
All Time:
12,049
Comments: 2
2 guide comments.
Go to guide comments
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
How to replace the battery of a HP EliteBook 850 G5 laptop. The images and information in this guide were taken from this computer's service manual.
Parts
Tools
      • Turn off the computer. If you are unsure whether the computer is off or in Hibernation, turn the computer on, and then shut it down through the operating system.
      • Disconnect the power from the computer by unplugging the power cord from the computer.
      • Disconnect all external devices from the computer.
      • Turn the computer upside down on a flat surface.
      Ask FixBot
    1. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover screws: step 2, image 1 of 1
      • Loosen the eight captive screws that secure the bottom cover.
      • Loosen the two inset captive screws that secure the bottom cover.
      Ask FixBot
    2. HP EliteBook 850 G5 Battery Replacement, Remove the bottom cover: step 3, image 1 of 1
      • Starting under the middle of the display, pry and lift the bottom cover off the computer. Consider using a spudger.
      Ask FixBot
    3. HP EliteBook 850 G5 Battery Replacement, Disconnect the battery: step 4, image 1 of 1
      • Disconnect the battery cable from the system board.
      • Remove the four Torx T8 2.0×4.0 screws.
      Ask FixBot
    4. HP EliteBook 850 G5 Battery Replacement, Remove the battery: step 5, image 1 of 1
      • Rotate the top of the battery upward, and then lift the battery out of the computer.
      Ask FixBot
To replace the battery & reassemble your device, follow these instructions in reverse order.
7 other people completed this guide.
Max Kletskov
42,195 Reputation
16 Guides authored
2 Guide Comments
Super Anleitung. Keine 10 min da war der Akku getauscht inkl. Reinigung 👍🏼
Marcus van Pluer - Reply Share
Akkutauschanleitung gut gefunden. Der Austausch war einfach und gut beschrieben.
K. Gnann - Reply Share
Past 24 Hours: 3
Past 7 Days: 54
Past 30 Days: 202
All Time: 12,049
