HP EliteBook 850 G3 WiFi Card Replacement
    1. HP EliteBook 850 G3 WiFi Card Replacement, WiFi Card: step 1, image 1 of 1
      • Turn off your laptop before starting
      • Flip the laptop over so the model stickers face the ceiling.
      Ask FixBot
    2. HP EliteBook 850 G3 WiFi Card Replacement: step 2, image 1 of 2 HP EliteBook 850 G3 WiFi Card Replacement: step 2, image 2 of 2
      • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
      Ask FixBot
    3. HP EliteBook 850 G3 WiFi Card Replacement: step 3, image 1 of 2 HP EliteBook 850 G3 WiFi Card Replacement: step 3, image 2 of 2
      • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
      Ask FixBot
    4. HP EliteBook 850 G3 WiFi Card Replacement: step 4, image 1 of 1
      • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
      Ask FixBot
    5. HP EliteBook 850 G3 WiFi Card Replacement: step 5, image 1 of 2 HP EliteBook 850 G3 WiFi Card Replacement: step 5, image 2 of 2
      • Slide out the WiFi card.
      Ask FixBot
    6. HP EliteBook 850 G3 WiFi Card Replacement: step 6, image 1 of 3 HP EliteBook 850 G3 WiFi Card Replacement: step 6, image 2 of 3 HP EliteBook 850 G3 WiFi Card Replacement: step 6, image 3 of 3
      • Disconnect the primary and secondary antenna wires from the WiFi card.
      • These are often marked with a white #1 and a black #2 (if there are two they are always marked.) note orientation to make clipping them onto your replacement card a little easier.
      Ask FixBot
2 other people completed this guide.
Annabeth Grover
1,075 Reputation
5 Guides authored
USF Tampa, Team S1-G1, Leahy Fall 2019 Member of USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 Members
60 Guides authored
1 Guide Comment
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
MV9000 - Reply Share
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 44
All Time: 2,339
